Using a B402 SOM chipset (cellular modem)
To use PowerShell’s Invoke-WebRequest command, what would be the equivalent command to:
curl https://api.particle.io/v1/products/vaporox-cell-16980/sims
-d sims[]=<redacted>
-d access_token=<redacted>
(where the sims[] data is the IICID of the SOM’s radio)
…I tried a bunch of combinations, but PowerShell always gives some type of error!
Welcome to the Community !
Have you seen this already ?
Hope will help
Thanks for the info…but I don’t understand most of it…Just need to send 2 data items, the access token and the IICID number. Does anyone have a simple Invoke command that’ll do this?
system
Closed
December 6, 2022, 7:25am
4
