Hi all
The Firmware documentation says you can do these number to string conversions:
String stringOne = String(45, HEX);
String stringOne = String(analogRead(0), DEC);
But I want to convert a Long value to a base 32 string. In Java I can do this:
Long value = 251415;
String valueAsString = Long.toString( value, 32 );
Is there an equivalent function in Wiring? That is how do I convert a Long value to a base 32 string in Wiring,
Thanks in advance
PQ
You could try the C function void itoa(int input, char *buffer, int radix)
On these 32bit µC it’s the same as ltoa() and lltoa() could be used for 64bit long long numbers.
My purpose in moving to base 32 string encoding is so I can cram more information into the 63 bytes of an event.
I can now answer my own question. On the server side I am using these javascript procedures to do the encoding/decoding:
- value.toString(32)
- parseInt( value, 32 )
In Wiring I use these procedures to do the same thing:
String numToString32( long value )
String answer = "";
if( value == 0 )
answer = "0";
else
boolean negative = ( value < 0 );
if( negative)
value = - value;
while( value > 0 )
int remainder = (int) ( value % 32 ); //(value - ( value / 32 ) );
value = value / 32;
char theChar = theAlphabet.charAt( remainder );
answer = theChar + answer;
if( negative)
answer = "-" + answer;
return answer;
long string32ToNum( String value )
long answer = 0;
boolean negative = false;
unsigned int i = 0;
for( ; i < value.length(); i++ )
char theChar = value.charAt(i);
if( theChar == '-' )
negative = true;
// Strip of any preceding minus signs or preceding zeros
if( ( theChar != '-' ) && theChar != '0' )
break;
answer = answer*32 + theAlphabet.indexOf(theChar);
if( negative )
answer = - answer;
return answer;
I’ve compared the results of the above procedures against the standard Java / Javascript functions using “round-trip” test cases on a handful of values (positive, negative and zero). I’ve also tested the parsing of strings left-padded with “0”. I’m using it on my Core and server, and all seems to work with round-trip messaging. Lightly tested so far but looking good.
If I discover any bugs I’ll update this post.
Hmmm. The procedure numToString32 stopped working at some stage after I posted it. I suspect (but can’t prove) compiler changes. I needed to modify it to get it working again. Here is the revised code:
const String theAlphabet = "0123456789abcdefghijklmnopqrstuvw";
// Convert a base 32 encoded string to a long. Mirrors behaviour of Java function Long.parseLong( value, 32 );
String answer = "";
if( value == 0 )
answer = "0";
else
if( negative)
value = - value;
while( value > 0 )
answer = theAlphabet.substring( remainder, remainder+1 ) + answer;
value = value / 32;
if( negative)
return answer;
