Convert Grove sensor degrees to Hue
HI folks,
This might be more of a math question than Particle.
I’d like to take the degree of angle from a Grove rotary angle sensor (0-300) and convert that to a value between 0-65535 which represents the color hue range of a Philips Hue bulb. My math is little rusty. :blush:
Can anyone recommend how to achieve this?
Thanks.
map() would be the function that springs to mind
However, the math for that is reeeealy simple and straight forward :wink:
 x * 65535.0 / 300.0
@ScruffR thank you! I realized just after posting that map() would be suitable. Nonetheless, thanks for the quick reply!
