Controlling a 3v motor directly from a Photon
im wanting a simple way of switching on a 3v dc motor then reversing for a couple of seconds each time, this wont be a constant running motor just a slight pulse now and again.
any ideas?
I would use a H-Bridge motor driver, like this one, if the motor requires less than 800 mA.
Note that the 3V3 output on the Photon usually does not have enough capacity to power a motor, so you will need to use a separate power supply for the motor.
anything more than 800mA? thanks
I don’t have a recommended high-current H-Bridge, but if you Google “H-Bridge”, it won’t be hard to find one. There was a cheap 2A module on Amazon, and a much more expensive but professional-looking 7A one, amongst many.
There is a dedicated shield for the Photon with 2A MOSFET H-Bridge
(the 6V min rating is there for when you need to power the Photon off that board - when driving the board with less you need to remove the Vin connection and power the Photon otherwise)
