Hi all,
Is there a way to log out from your firmware code? If so, where does it get printed?
Hi all,
Currently there’s no web logger, but that’s a feature we have planned. In the meantime, if you want logging, you can plug in the USB connector to your computer and open a Serial connection, and Serial.print() to print out messages through a Serial terminal.
The COM port does not show up. Do I need to install a driver?
On Windows, yes; take a look here:
We'll be adding the driver to our documentation as well.
Serial port seems to only appear in listening mode.
Is there a way to enable serial when core is connected to WiFi and is flashed with custom code?
@suda Simply use Serial.begin(9600); in setup()
You can then use Serial.print() or Serial.println() to output stuff to the terminal…
More info here: http://docs.spark.io/#/firmware/communication-serial
EDIT: here’s the driver https://s3.amazonaws.com/spark-website/Spark.zip
suda, if I can just add to what kennethlimpcp said, the baudrate in the Serial.begin() call can be set up to 115200 baud. I develop in Win8.1 so I use putty portable as a terminal and I have saved the presets for all the com ports my sparks use. The trick is to get the driver installed but after that, it is very easy to use.
@kennethlimcp and @peekay123 thanks! Works like a charm
