My core was posting to Librato just fine for many weeks. I had to modify the API key in Librato so I also went in and deleted my webhook and recreated it with the updated auth credentials but now my hook-response is “Credentials are required to access this resource.” I’ve triple check it and even reverted back to how it was originally but no dice. I am able to push to Librato using curl with these creditials but not with the webhook.
Here is my webhook.
Thanks for any help!
"eventName": "librato_",
"url": "https://metrics-api.librato.com/v1/metrics",
"requestType": "POST",
"auth": {
"username": "myapiusernamehere",
"password": "myapikeyhere"
"json": {
"gauges": [
"name": "{{SPARK_EVENT_NAME}}",
"value": "{{SPARK_EVENT_VALUE}}",
"source": "{{SPARK_CORE_ID}}"
"mydevices": true
