Connecting Particle (Spark Core) to Blynk Error
After the introduction of the New Blueprint with Particle! on 31st August 2023, which helps connect Particle devices to Blynk, I tried it out but I am getting errors when compiling the code generated by the Blueprint. I’m using a Core with the latest update. See the below code followed by the error.
#include "Particle.h"
#include <math.h> // This library is only for function simulating a sensor
const char *firmware_version = "0.0.0";
double v15 = 3.14159;
uint32_t simSensor_timer_last = 0; // This is a variable for a function that simulates a sensor
uint8_t led_state = LOW;
bool particle_fn_called = TRUE; // causes the device to publish data immediately after started/boot and connected to the Particle cloud.
// Register the Particle cloud function
int blynkLED(String on_or_off);
// Blynk
// Update below with your Blynk auth token for your device (automatically populated by Blueprint)
#define BLYNK_TEMPLATE_ID "<---redacted--->"
#define BLYNK_TEMPLATE_NAME "Connect a Particle device"
#define BLYNK_AUTH_TOKEN "<---redacted--->"
void simSensor()    //This function simulates a sensor
  long sim = random(millis());
  if (millis() - simSensor_timer_last >= 20000) {
    simSensor_timer_last = millis();
    float deltaSensor = cos(float(sim) / 1000) / 100;
       if (v15 <= 0 || v15 >= 3.3)
      v15 = v15 - deltaSensor;
    else
      v15 = v15 + deltaSensor;
} // simSensor
bool deviceHasLedOnD7()
  // Returns TRUE if the device has a built-in LED on D7:
  //  Boron, Argon, Photon 2, Photon, Electron, Core
  // 8: P1
  switch (PLATFORM_ID)
  case PLATFORM_BORON:
  case PLATFORM_ARGON:
  case 0:  // Core
  case 6:  // Photon  (PLATFORM_PHOTON_PRODUCTION)
  case 10: // Electron  (PLATFORM_ELECTRON_PRODUCTION)
    return TRUE;
  default:
    return FALSE;
} // deviceHasLedOnD7()
// Timer
const uint32_t TIMER_INTERVAL_MS = 300000L;
uint32_t timer_last = 0;
void pubToParticleBlynk()
  if (Particle.connected())
    char data[90]; // See serial output for the actual size in bytes and adjust accordingly.
    // Note the escaped double quotes around the ""t"" for BLYNK_AUTH_TOKEN.
    snprintf(data, sizeof(data), "{\"t\":\"%s\",\"v14\":%u,\"v15\":%f,\"v16\":%u,\"v17\":%u}", BLYNK_AUTH_TOKEN, millis(), v15, led_state, led_state);
    Serial.printlnf("Sending to Blynk: '%s' with size of %u bytes", data, strlen(data));
    bool pub_result = Particle.publish("blynk_https_get", data, PRIVATE);
    if (pub_result)
    else
      Serial.println("ERROR: Particle.publish()");
} // pubToParticleBlynk()
void pubTimer()
  // A timer for publishing data to Particle Cloud, and then continuing to Blynk.
  if (timer_last > millis())
  if ((millis() - timer_last) > TIMER_INTERVAL_MS && Particle.connected())
    pubToParticleBlynk();
} // pubTimer()
  if (deviceHasLedOnD7() == TRUE)
    pinMode(D7, OUTPUT);
    digitalWrite(D7, LOW);
  waitFor(Serial.isConnected, 30000);
  delay(1000);
  Serial.printlnf("Device OS v%s", System.version().c_str());
  Serial.printlnf("Free RAM %lu bytes", System.freeMemory());
  Serial.printlnf("Firmware version v%s", firmware_version);
  // register the Particle cloud function (funcKey, funcName)
  Particle.function("blynk_led", blynkLED);
  Serial.println("Setup complete");
} // setup()
  simSensor(); // This is function simulates a sensor
  pubTimer();
  if (particle_fn_called == TRUE)
    particle_fn_called = FALSE;
    // Publish data to Particle cloud..
    digitalWrite(D7, led_state);
} // loop()
int blynkLED(String on_off)
  // Custom Particle cloud function that changes the state of the built-in LED
  // on D7 in response to an instruction from Blynk calling this
  // custom cloud function.
  // Returns the value 1 if the LED has been turned on, and 0 if turned off,
  // -1 if an unexpected on_off value is received.
  // Cloud functions must return int and take one String argument
  // curl https://api.particle.io/v1/devices/{your 25 char device id}/blynk_led
  // -d access_token={your 40 char access token}
  // -d "args=on/off"
  if (on_off == "on" || on_off == "1")
    led_state = HIGH;
    return 1;
  else if (on_off == "off" || on_off == "0")
    led_state = LOW;
    return 0;
  else
    Serial.print("Unexpected on_off value of: '");
    Serial.print(on_off);
    Serial.println("'");
  return -1;
} // blynkLED()
HERE IS THE ERROR
Processing  blynxparticleexample02.ino
make -C ../newlib_nano
make[1]: Entering directory '/firmware/newlib_nano'
make[1]: Nothing to be done for 'all'.
make[1]: Leaving directory '/firmware/newlib_nano'
make -C ../user
make[1]: Entering directory '/firmware/user'
Building cpp file: blynxparticleexample02.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-0-lto
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -DSPARK_PLATFORM -DFLASHEE_EEPROM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=1.2.1-rc.2 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/src -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../dynalib/inc -I -I./libraries -I. -MD -MP -MF ../build/target/user/platform-0-ltoblynxparticleexample02.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=CC3000 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DMODULE_VERSION=1211 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -std=gnu++14 -c -o ../build/target/user/platform-0-ltoblynxparticleexample02.o blynxparticleexample02.cpp
blynxparticleexample02.ino: In function 'void pubToParticleBlynk()':
blynxparticleexample02.ino:71:149: warning: format '%u' expects argument of type 'unsigned int', but argument 5 has type 'system_tick_t {aka long unsigned int}' [-Wformat=]
Building target: ../build/target/user/platform-0-ltolibuser.a
Invoking: ARM GCC Archiver
arm-none-eabi-gcc-ar -cr ../build/target/user/platform-0-ltolibuser.a ../build/target/user/platform-0-ltoblynxparticleexample02.o
make[1]: Leaving directory '/firmware/user'
make -C ../wiring
make[1]: Entering directory '/firmware/wiring'
make[1]: Leaving directory '/firmware/wiring'
make -C ../hal
make[1]: Entering directory '/firmware/hal'
make[1]: Leaving directory '/firmware/hal'
make -C ../system
make[1]: Entering directory '/firmware/system'
make -C ../third_party/miniz
make[2]: Entering directory '/firmware/third_party/miniz'
make[2]: Nothing to be done for 'all'.
make[2]: Leaving directory '/firmware/third_party/miniz'
make[1]: Leaving directory '/firmware/system'
make -C ../services
make[1]: Entering directory '/firmware/services'
make -C ../third_party/nanopb
make[2]: Entering directory '/firmware/third_party/nanopb'
make[2]: Leaving directory '/firmware/third_party/nanopb'
make[1]: Leaving directory '/firmware/services'
make -C ../communication
make[1]: Entering directory '/firmware/communication'
make[1]: Leaving directory '/firmware/communication'
make -C ../platform
make[1]: Entering directory '/firmware/platform'
make[1]: Leaving directory '/firmware/platform'
make -C ../wiring_globals
make[1]: Entering directory '/firmware/wiring_globals'
make[1]: Leaving directory '/firmware/wiring_globals'
make -C ../crypto
make[1]: Entering directory '/firmware/crypto'
make -C ../third_party/mbedtls
make[2]: Entering directory '/firmware/third_party/mbedtls'
make[2]: Leaving directory '/firmware/third_party/mbedtls'
make[1]: Leaving directory '/firmware/crypto'
Building c file: src/module_info.c
Invoking: ARM GCC C Compiler
mkdir -p target/obj/./src/
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DMBEDTLS_CONFIG_FILE="<mbedtls_config.h>" -DSYSTEM_VERSION_STRING=1.2.1-rc.2 -DRELEASE_BUILD -Werror -I../user/inc -I../wiring/inc -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/src -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../crypto/inc -I../third_party/mbedtls/mbedtls/include -I../dynalib/inc -I. -MD -MP -MF target/obj/./src/module_info.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DMODULE_VERSION=1211 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE  -std=gnu11 -Wno-pointer-sign -c -o target/obj/./src/module_info.o src/module_info.c
Building file: ../build/arm/startup/startup_stm32f10x_md.S
Invoking: ARM GCC Assembler
mkdir -p target/obj/startup/
arm-none-eabi-gcc -g3 -gdwarf-2 -mcpu=cortex-m3 -mthumb -I../build/arm/startup -Wa,--defsym -Wa,SPARK_INIT_STARTUP=1 -x assembler-with-cpp -fmessage-length=0 -c -o target/obj/startup/startup_stm32f10x_md.o ../build/arm/startup/startup_stm32f10x_md.S
Building target: target/workspace.elf
Invoking: ARM GCC C++ Linker
mkdir -p target/
arm-none-eabi-g++ -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DMBEDTLS_CONFIG_FILE="<mbedtls_config.h>" -DSYSTEM_VERSION_STRING=1.2.1-rc.2 -DRELEASE_BUILD -Werror -I../user/inc -I../wiring/inc -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/src -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../crypto/inc -I../third_party/mbedtls/mbedtls/include -I../dynalib/inc -I. -MD -MP -MF target/workspace.elf.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DMODULE_VERSION=1211 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE target/obj/./src/module_info.o  target/obj/startup/startup_stm32f10x_md.o --output target/workspace.elf -nostartfiles -Xlinker --gc-sections -flto -Os -fuse-linker-plugin -Tlinker_stm32f10x_md_dfu.ld -L../build/arm/linker --specs=nano.specs -lc -lnosys -u _printf_float -Wl,-Map,target/workspace.map  -L../build/target/user/platform-0-lto -L../build/target/wiring/platform-0-lto/ -L../build/target/system/platform-0-lto/ -L../build/target/services/platform-0-lto/ -L../build/target/communication/platform-0-lto-prod-0/ -L../build/target/hal/platform-0-lto/ -L../build/target/platform/platform-0-lto/ -L../build/target/wiring_globals/platform-0-lto/ -L../build/target/crypto/platform-0-lto/ -L../build/target/newlib_nano/platform-0-lto -L../build/target/miniz/platform-0-lto -L../build/target/nanopb/platform-0-lto -L../build/target/mbedtls/platform-0-lto -L../build/arm/linker -Wl,--whole-archive -lnewlib_nano -luser -lwiring -lhal -lsystem -lservices -lcommunication -lplatform -lwiring_globals -lcrypto -lminiz -lnanopb -lmbedtls -Wl,--no-whole-archive
/usr/local/gcc-arm-embedded/bin/../lib/gcc/arm-none-eabi/5.3.1/../../../../arm-none-eabi/bin/ld: target/workspace.elf section `.data' will not fit in region `APP_FLASH'
/usr/local/gcc-arm-embedded/bin/../lib/gcc/arm-none-eabi/5.3.1/../../../../arm-none-eabi/bin/ld: region `APP_FLASH' overflowed by 792 bytes
../build/module.mk:232: recipe for target 'target/workspace.elf' failed
make: *** [target/workspace.elf] Error 1
I have basic programming skills. Please help.
This is the important part of the error log
To see it you need to go all the way down and then scroll right
Your application code will not fit into the rather limited flash of the Core.
You need to trim your code down.
The easiest start would be to shorten or remove all static text as much as you can and maybe even drop some of the Serial.print() statements completely.
Thanks, this solved it. I had to drop a lot of the Serial.print() statements.
