Connected LED to 3V3 instead of GND
I just got my core.
I was trying out the first project “Blink and LED”. See http://docs.spark.io/examples/
However, instead of connecting the LED to GND, I connected it to 3V3. The LED lighted up.
Subsequently, when I correctly connected the LED to GND, the LED would not light up again.
Did I just spoil my core?
Can someone advise?
Thanks.
You probably reversed the LED but it’s fine since blinking still works! The core is OK :smiley:
Hi Kenneth,
Thanks for the prompt reply.
Would you know why the LED would not light up again when I connect it correctly and run the program? (I have verified that the LED is working)
When I do a spark call digitalWrite “D1,HIGH”, I get a -1. Not sure if that means anything.
Hi @Kane,
It’s really easy to burn out an LED if you overpower it, the Core is probably fine, but it’s possible you let out the magic smoke from the LED. :slight_smile:
David
Are you trying with Tinker App?
Check that you are connected like this:
D1 -----> LED+ (longer leg) ----------LED- ------------ Resistor ------- GND
A sample code to flash will be:
 pinMode(D1, OUTPUT);
 digitalWrite(D1, LOW);
 delay(500);
 digitalWrite(D1, HIGH);
 delay(500);
Hi @Dave,
I have checked that the LED is working fine.
However, I cannot get the LED to blink or light up when I run the program. Just wondering if the pins are ok?
Regards
Hi @Kane,
Although it’s unlikely, you could destroy a GPIO pin by shorting 3v3 to that pin while it’s set to OUTPUT and being pulled LOW.
David
Dear @Dave,
I see. Is there a way to check the pins using a multimeter or any diagnostic software?
Regards
@kenneth,
Ah, I see what is the problem. I connected the resistor between D0 and LED+.
The LED is flashing now. :smile:
Thanks so much for your help. I was stumped for so long.
Regards
