Connected Garage Door Opener using Photon and Android
GarageBot: A Connected Garage Door Opener
Wanted to share my first Photon project, I created a connected garage door opener using a Photon and an Android app. The project uses a simple relay to open and close the door from the Android app, and a proximity sensor to detect whether the door is open or closed.
You can find the hardware specs, firmware, and Android code on hackster. https://www.hackster.io/courtachen/garagebot-the-connected-garage-door-opener-e21dff?ref=explore&ref_id=recent___&offset=1
Looks good. Though you should probably have a flyback diode across the relay coil.
Thanks, and good call I will add a flyback diode.
Cool case. Haven’t seen those before.
Thanks for posting, simple yet elegant project.
