Confirm relay shield sample image
In Particle datasheets there is a sample set up for the Relay Shield.
https://docs.particle.io/datasheets/photon-shields/#relay-shield-sample-setup
The image shows an AC wiring example which I believe is incorrect. When switching AC you should switch the hot wire which for AC in the United States should be the black wire. White would be neutral. Please confirm that in the example you are showing you should actually have black (hot) running into “Comm” then black (hot) running out of NO or NC to the appliance, a lamp bulb in this example. Then from the other side of the bulb white (neutral) should then return to your grounded neutral bar. In the US for AC a red wire would normally be another hot wire to make 220.
Thank you for reviewing.
@tkurtz great question… disclaimer: I’m not a licensed electrician, and you should check your country and city’s building codes to know for sure. Yes that’s true typically the HOT (black… but not always black) wire is the switched wire to a lamp or fan. The HOT gets switched through a wall switch. However, the US 110VAC outlet typically has both HOT (the small prong) and NEUTRAL (the large prong) and GROUND (the roundish prong). Yes the HOT should be switched, presumably so that when it’s off and you are unscrewing the light bulb you are MORE protected. You CAN still get shocked by the neutral wire because you should not assume you are grounded to the same point that the neutral bus bar is, there can be a differential. Make sure you use a cord that has a polarized connector so you cannot invert the plug later on. Finally, BE SAFE and unplug the entire circuit before changing the lightbulb or fiddling with the AC load or relay shield :wink:
Reference on outlet types: Don't take my word for it (or Wikipedia's for that matter)! I assume no liability for your wiring mishaps. AC is dangerous. Be safe, be smart! Hiring a certified electrician can save your life.
Thank you for the quick reply and showing so much concern for my safety. I appreciate it. :smile:
My concern is that the sample wiring image that particle is publishing is incorrect which might cause confusion, frustration or endanger those that don’t have enough knowledge to question it.
I just want to raise the question/concern to particle’s attention so it can be reviewed or addressed if needed.
Thanks again!
@tkurtz,
I looked at the physical Relay Shield that have and the image you are concerned. Seems like there’s no issue? :smile:
@tkurtz I added a Docs github issue for this so we don’t forget, thanks!
