Hello Guys
Please I need to concatenate the even't data from two spark cores and save them in a text file. I have modified the code below (Thanks to @harrisonhjones) to make it save the data from one even't core but how can I do it with two cores? I tried to change the code, but I got an undefined at the output:
Here is the code:
/*jslint node: true */
"use strict";
var spark = require('spark');
var fs = require('fs');
// Variables for converting the Timestamp from GMT to locale time
var d=0;
var nd=0;
var utc=0;
// Variables for concatenating the data from events of two cores (Event1's data&&Event2's data)
var fd=0;
var c1=0;
var c2=0;
// Login and start doing things!
spark.on('login', function() {
//Get the locale time instead of UTC/GMT
function calcTime(city, offset) {
d = new Date();
utc = d.getTime() + (d.getTimezoneOffset() * 60000);
nd = new Date(utc + (3600000*offset));
return " Published at " + nd.toLocaleString();
//Get test event for specific core
spark.getEventStream('Event1', '0000000000000000000000', function(data) {
console.log("New Event: " + JSON.stringify(data) + ". Logging it to file");
c1=data.data;
spark.getEventStream('Event2', '0000000000000000000000', function(data1) {
console.log("New Event: " + JSON.stringify(data1) + ". Logging it to file");
c2=data1.data1;
fd= c1.concat(c2);
fs.appendFile('Final Concatenated Data.txt', fd + "," +
calcTime('MyCity','-5.0') + "," + 'Final Concatenated Data' + "\r\n", function (err) {
if(err)
console.log("File log failure. Error = " + JSON.stringify(err));
else
console.log("File log success");
// Login as usual
spark.login({ username: 'myemail@gmail.com', password: 'mypassword'});
At the output I got the first data which is c1 and I got undefined symbol instead of the second data as shown below:
SA0Eundefined , Published at Fri Jul 03 2015 21:49:29 GMT-0500 (Central Daylight Time),Final Cancatinated Data
where SA0E is for the second event's data (c2), and undefined for the first event's data (c2).
I guess that the undefined word appeared because I'm trying to use the c1 in the function of the c2 , so it couldn't get the data since it is inside a function. If I'm right, how can solve that?
Any suggestion please?
Thanks in advance.,
