Computers think spark is a Serial Mouse?
Hi guys,
I’ve been experimenting with my sparks using the HTTP client library and example to post data to a emoncms server on a Rpi successfully. Recently I’ve encountered a problem that when the core starts breathing cyan when connected to either of my computers (One on Win7 one on Win8) the computer recognises them as a serial mouse. The cursor starts jumping around the screen and randomly left or right clicking on things. The chrome browser I currently have open freezes. Then when I re-open another chrome browser, if you click on a tab it closes the tab. All of which is after I’ve disconnected the spark from the USB. The only fix I’ve come across so far is too restart the computer.
Can anyone shed some light on this?
Code:
#include "application.h"
#include "HttpClient/HttpClient.h"
* Declaring the variables.
unsigned int nextTime = 0;    // Next time to contact the server
HttpClient http;
http_header_t headers[] = {
    //  { "Content-Type", "application/json" },
    //  { "Accept" , "application/json" },
    { "Accept" , "*/*"},
http_request_t request;
http_response_t response;
    Serial.println("Wales");
if (millis() - nextTime > 10000UL){}
    Serial.println();
    Serial.println("Application>\tStart of Loop.");
    // Request path and body can be set at runtime or at setup.
    request.ip = {192,168,xxx,xxx};
    request.port = 80;
    request.path = "/emoncms/input/post.json?json={power:200}&apikey=3b172c8064620d9de6dcb4550b49xxxx";
    // The library also supports sending a body with your request:
    // Get request
    http.get(request, response, headers);
    Serial.print("Application>\tResponse status: ");
    Serial.println(response.status);
    Serial.print("Application>\tHTTP Response Body: ");
    Serial.println(response.body);
    nextTime = millis() + 10000;
Yup, try searching for ‘mouse’. There have been some topic about this exact issue in the past which have been solved in their respective topics.
@Moors7 is right on here--it is a Windows problem and happens with other USB devices. The fix is here:
