Compiler error when using WebServer
I have a very simple program:
#include <WebServer.h>
#include  <spark_wiring_i2c.h>
#include <application.h>
which results in the following. Any suggestions on how to correct?
Processing  test1.ino
Checking library WebServer...
Installing library WebServer 0.0.2 to lib/WebServer ...
Library WebServer 0.0.2 installed.
make -C ../modules/photon/user-part all
make[1]: Entering directory '/firmware/modules/photon/user-part'
make -C ../../../user
make[2]: Entering directory '/firmware/user'
Building cpp file: src/test1.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-6-msrc/
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F2XX -DPLATFORM_THREADING=1 -DPLATFORM_ID=6 -DPLATFORM_NAME=photon -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD006 -DUSBD_PID_CDC=0xC006 -DSPARK_PLATFORM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=6 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=0.6.3 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../services/inc -I../communication/src -I../hal/inc -I../hal/shared -I../hal/src/photon -I../hal/src/stm32f2xx -I../hal/src/stm32 -I../hal/src/photon/api -I../platform/shared/inc -I../platform/MCU/STM32F2xx/STM32_USB_Host_Driver/inc -I../platform/MCU/STM32F2xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_OTG_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F2xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F2xx/CMSIS/Include -I../platform/MCU/STM32F2xx/CMSIS/Device/ST/Include -I../dynalib/inc -Isrc -I./libraries -Isrc -Isrc -Isrc -Isrc -Ilib/WebServer/src -I. -MD -MP -MF ../build/target/user/platform-6-msrc/test1.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=BCM9WCDUSI09 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSE_THREADING=0 -DUSE_SPI=SPI -DUSE_CS=A2 -DUSE_SPI=SPI -DUSE_CS=A2 -DUSE_THREADING=0 -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0x80A0000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=4 -DMODULE_FUNCTION=5 -DMODULE_INDEX=1 -DMODULE_DEPENDENCY=4,2,109 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -std=gnu++11 -c -o ../build/target/user/platform-6-msrc/test1.o src/test1.cpp
In file included from src/test1.cpp:2:0:
lib/WebServer/src/WebServer.h:181:1: error: expected class-name before '{' token
lib/WebServer/src/WebServer.h:203:41: error: 'uint16_t' has not been declared
   WebServer(const char *urlPrefix = "", uint16_t port = 80);
lib/WebServer/src/WebServer.h:330:24: error: 'uint8_t' has not been declared
   virtual size_t write(uint8_t);
lib/WebServer/src/WebServer.h:331:30: error: 'uint8_t' does not name a type
   virtual size_t write(const uint8_t *buffer, size_t size);
lib/WebServer/src/WebServer.h:334:3: error: 'uint8_t' does not name a type
   uint8_t available();
lib/WebServer/src/WebServer.h:344:3: error: 'TCPServer' does not name a type
   TCPServer m_server;
lib/WebServer/src/WebServer.h:345:3: error: 'TCPClient' does not name a type
   TCPClient m_client;
lib/WebServer/src/WebServer.h:369:3: error: 'uint8_t' does not name a type
   uint8_t m_buffer[WEBDUINO_OUTPUT_BUFFER_SIZE];
lib/WebServer/src/WebServer.h:370:3: error: 'uint8_t' does not name a type
   uint8_t m_bufFill;
lib/WebServer/src/WebServer.h:395:45: error: 'uint16_t' has not been declared
 WebServer::WebServer(const char *urlPrefix, uint16_t port) :
lib/WebServer/src/WebServer.h: In constructor 'WebServer::WebServer(const char*, int)':
lib/WebServer/src/WebServer.h:396:3: error: class 'WebServer' does not have any field named 'm_server'
   m_server(port),
lib/WebServer/src/WebServer.h:397:3: error: class 'WebServer' does not have any field named 'm_client'
   m_client(),
lib/WebServer/src/WebServer.h:405:3: error: class 'WebServer' does not have any field named 'm_bufFill'
   m_bufFill(0)
lib/WebServer/src/WebServer.h: In member function 'void WebServer::begin()':
lib/WebServer/src/WebServer.h:413:3: error: 'm_server' was not declared in this scope
   m_server.begin();
lib/WebServer/src/WebServer.h: At global scope:
lib/WebServer/src/WebServer.h:440:25: error: 'size_t WebServer::write' is not a static member of 'class WebServer'
 size_t WebServer::write(uint8_t ch)
lib/WebServer/src/WebServer.h:440:25: error: 'uint8_t' was not declared in this scope
lib/WebServer/src/WebServer.h:441:1: error: expected ',' or ';' before '{' token
In file included from /usr/local/gcc-arm-embedded/arm-none-eabi/include/c++/4.9.3/ios:39:0,
                 from /usr/local/gcc-arm-embedded/arm-none-eabi/include/c++/4.9.3/ostream:38,
                 from ../wiring/inc/spark_wiring_string.h:234,
                 from ../wiring/inc/spark_wiring_stream.h:30,
                 from ../wiring/inc/spark_wiring_i2c.h:30,
                 from src/test1.cpp:4:
/usr/local/gcc-arm-embedded/arm-none-eabi/include/c++/4.9.3/exception:35:37: error: expected declaration before end of line
 #pragma GCC visibility push(default)
../build/module.mk:267: recipe for target '../build/target/user/platform-6-msrc/test1.o' failed
make[2]: Leaving directory '/firmware/user'
make[2]: *** [../build/target/user/platform-6-msrc/test1.o] Error 1
../../../build/recurse.mk:11: recipe for target 'user' failed
make[1]: Leaving directory '/firmware/modules/photon/user-part'
make[1]: *** [user] Error 2
../build/recurse.mk:11: recipe for target 'modules/photon/user-part' failed
make: *** [modules/photon/user-part] Error 2
What system version are you targeting?
You shouldn’t need #include <spark_wiring_i2c.h>
It looks like your source file name is test1.cpp. When you use a .cpp file (instead of a .ino file) you must include particle.h first, as in:
#include "Particle.h"
#include "WebServer.h"
You can leave out the other two.
@rickkas7 Perfect! Thanks for the quick help. Not really sure what is going on as the file where I’m really using the headers does end in ino. Regardless your solution worked.
