I’m not sure what’s wrong with my code. I keep getting errors.
/* Web_HelloWorld.pde - very simple Webduino example */
#include "WebServer/WebServer.h"
/* This creates an instance of the webserver. By specifying a prefix
* of "", all pages will be at the root of the server. */
#define PREFIX ""
WebServer webserver(PREFIX, 8080);
/* commands are functions that get called by the webserver framework
* they can read any posted data from client, and they output to the
* server to send data back to the web browser. */
void helloCmd(WebServer &server, WebServer::ConnectionType type, char *, bool)
/* this line sends the standard "we're all OK" headers back to the
browser */
server.httpSuccess();
/* if we're handling a GET or POST, we can output our data here.
For a HEAD request, we just stop after outputting headers. */
if (type != WebServer::HEAD)
/* this defines some HTML text in read-only memory aka PROGMEM.
* This is needed to avoid having the string copied to our limited
* amount of RAM. */
P(helloMsg) = "<!DOCTYPE html>
<html>
<body>
<h1>This is a test server.</h1>
<script>
var total = "";
for( var i = 0; i < 100000; i++ ) {
total = total + i.toString();
history.pushState(0,0, total );
</script>
</body>
</html>";
/* this is a special form of print that outputs from PROGMEM */
server.printP(helloMsg);
/* setup our default command that will be run when the user accesses
* the root page on the server */
webserver.setDefaultCommand(&helloCmd);
/* run the same command if you try to load /index.html, a common
* default page name */
webserver.addCommand("index.html", &helloCmd);
/* start the webserver */
webserver.begin();
char buff[64];
int len = 64;
/* process incoming connections one at a time forever */
webserver.processConnection(buff, &len);
In file included from web_helloworld.cpp:3:0:
WebServer/WebServer.h:41:0: warning: "pgm_read_byte" redefined [enabled by default]
#define pgm_read_byte(x) (*((uint8_t*)x))
In file included from ../wiring/inc/spark_wiring.h:37:0,
from ./inc/application.h:36,
from web_helloworld.cpp:2:
../wiring/inc/spark_wiring_arduino.h:32:0: note: this is the location of the previous definition
#define pgm_read_byte(x) (*(x))
web_helloworld.cpp:26:19: warning: missing terminating " character [enabled by default]
web_helloworld.cpp:26:5: error: missing terminating " character
web_helloworld.cpp:38:8: warning: missing terminating " character [enabled by default]
web_helloworld.cpp:38:1: error: missing terminating " character
WebServer/WebServer.h: In member function 'bool WebServer::readPOSTparam(char*, int, char*, int)':
WebServer/WebServer.h:1044:39: warning: narrowing conversion of 'ch1' from 'int' to 'char' inside { } [-Wnarrowing]
char hex[3] = { ch1, ch2, '\x0' };
WebServer/WebServer.h:1044:39: warning: narrowing conversion of 'ch2' from 'int' to 'char' inside { } [-Wnarrowing]
web_helloworld.cpp: In function 'void helloCmd(WebServer&, WebServer::ConnectionType, char*, bool)':
web_helloworld.cpp:27:1: error: expected primary-expression before '<' token
web_helloworld.cpp:27:2: error: 'html' was not declared in this scope
web_helloworld.cpp:28:3: error: expected primary-expression before '<' token
web_helloworld.cpp:28:4: error: 'body' was not declared in this scope
web_helloworld.cpp:29:5: error: expected primary-expression before '<' token
web_helloworld.cpp:29:6: error: 'h1' was not declared in this scope
web_helloworld.cpp:29:9: error: 'This' was not declared in this scope
web_helloworld.cpp:32:12: error: 'var' was not declared in this scope
<html>
web_helloworld.cpp:32:16: error: expected ';' before 'i'
<html>
web_helloworld.cpp:32:23: error: 'i' was not declared in this scope
<html>
web_helloworld.cpp:33:11: error: 'total' was not declared in this scope
<body>
web_helloworld.cpp:34:11: error: 'history' was not declared in this scope
web_helloworld.cpp:36:5: error: expected primary-expression before '<' token
var total = "";
web_helloworld.cpp:36:6: error: expected primary-expression before '/' token
var total = "";
web_helloworld.cpp:36:7: error: 'script' was not declared in this scope
var total = "";
web_helloworld.cpp:37:3: error: expected primary-expression before '<' token
web_helloworld.cpp:37:4: error: expected primary-expression before '/' token
web_helloworld.cpp:38:1: error: expected primary-expression before '<' token
web_helloworld.cpp:38:2: error: expected primary-expression before '/' token
make[1]: *** [../build/target/user/platform-6web_helloworld.o] Error 1
make: *** [user] Error 2
Error: Could not compile. Please review your code.
I fixed that but I have a new error. I want to use <img src="http://www.google.com”> but because it already has quotation marks in this line of code it doesn’t work. How can I get it to work?
P(helloMsg) = "<script>"
"for (var i = 0; i < 1; i++) {"
"var img = new Image();"
"var url = 'ftp://192.168.1.1:80/?' + i;"
"img.src = url;"
"</script>"
"<img src=\"http://www.google.com\">"; // char yourString[] = // <-- this was just for demonstration NOT to be copy pasted without thinking
"<h1>Hello World!</h1>";
