Compile for multiple DeviceOS versions
I would like to do the following but at compile time using #ifdef.
Is there a way to tell the compiler the deviceOS version.
the online compiler uses the “–target x.x.x” option, so how to we get that flag into the code?
	if (System.versionNumber() < 0x001050000) {
		Wire.beginTransmission(MCP23017_ADDRESS | i2caddr);
	else {
		Wire.beginTransmission(WireTransmission(MCP23017_ADDRESS | i2caddr).timeout(100));
Heres what I would like. (psuedo code)
	#ifdef DEVICEOS < 0x001050000
    #else
	#endif
Marshall
always the way, you post, then find the answer!
https://docs.particle.io/reference/device-os/firmware/electron/#checking-for-features
