Hi all - I'm working on an Argon project I've been successfully using for a while now.
I can compile and flash locally no problem, but it fails when trying to do a cloud flash with the error:
MacBookPro:inverter_monitor chris$ particle compile argon . --target 6.4.1
Compiling code for argon
Targeting version: 6.4.1
Including:
lib/BackgroundPublishRK/src/BackgroundPublishRK.cpp
lib/BackgroundPublishRK/src/BackgroundPublishRK.h
lib/LocalTimeRK/src/LocalTimeRK.cpp
lib/LocalTimeRK/src/LocalTimeRK.h
lib/ModbusMaster-Particle/src/ModbusMaster-Particle.cpp
lib/ModbusMaster-Particle/src/ModbusMaster-Particle.h
lib/ModbusMaster-Particle/src/ModbusMaster-Particle/ModbusMaster-Particle.h
lib/ModbusMaster-Particle/src/util/arduino-electron-fixes.h
lib/ModbusMaster-Particle/src/util/crc16.h
lib/ModbusMaster-Particle/src/util/word.h
lib/PublishQueuePosixRK/src/PublishQueuePosixRK.cpp
lib/PublishQueuePosixRK/src/PublishQueuePosixRK.h
lib/SequentialFileRK/src/SequentialFileRK.cpp
lib/SequentialFileRK/src/SequentialFileRK.h
project.properties
src/inverter_monitor.ino
Compile failed: Compile input not allowed
But local compile is fine:
MacBookPro:inverter_monitor chris$ particle compile argon . --compiler local --target 6.4.1
Including:
project.properties
src/inverter_monitor.cpp
:::: COMPILING APPLICATION
Creating /Users/chris/development/inverter_monitor/target/6.4.1/argon/platform_user_ram.ld ...
text data bss dec hex filename
34504 178 1260 35942 8c66 /Users/chris/development/inverter_monitor/target/6.4.1/argon/inverter_monitor.elf
*** COMPILED SUCCESSFULLY ***
Compile succeeded.
Saved firmware to: /Users/chris/development/inverter_monitor/argon_firmware_1793216510087.bin
...and of course:
MacBookPro:inverter_monitor chris$ particle --version
3.52.3
Any ideas?
