Hi guys.
I’m doing a project, were my SparkCore needs to communicate with a server. In this case, I have chosen to develop the server in NodeJS. Since fast response is required in this project, I want to communicate between the SparkCore and NodeJS, without going through SparkCloud. Is this possible? I’ve tried to research a little, and all the frameworks I found, seem to communicate with the SparkCore through the SparkCloud API.
(I already figured out, that I can make SparkCore not connect to SparkCloud by using SYSTEM_MODE(SEMI_AUTOMATIC)
Bonus question: Is it possible to communicate between SparkCore and NodeJS using strings, like serial communication?
Thanks in advance!
