I have the below code running on a Particle Photon. It had been running fine for some time and a few weeks back I decided to update the Device OS from 1.2.1 to 1.4.0. After doing this, one of the Particle Subscriptions in my code wouldn’t run anymore (or at least the two particle variables that get updated within it don’t update). The problem subscription is “Fireplace_Temp” and the two variables that don’t get updated are “Fireplace_Temp” & “FP_Temp_TimeStamp”. I’ve played around with removing pieces of the code to see if something is blocking within that part of the code (including getting rid of the other Particle Subscription) without any luck.
When I originally had this issue several weeks ago, in the process of multiple flashes setting targets of older Device OS’s it started working again, but today I noticed it had stopped working and after playing with it quite a bit (both through troubleshooting the code and trying other target Device OS’s) I haven’t gotten it to work again. I’ve verified that the originating/publishing device is indeed publishing the event, so that’s not the issue.
Any ideas? I’m guessing that maybe I’m doing something improper and I was just getting lucky with it working before? Please, teach me the errors of my ways.
#include <OneWire.h>
#include "DS18.h"
DS18 sensor(D0);
#define Extra_Low D1
#define Low D2
#define Medium D3
#define High D5
#define Power D4
bool Heating_Season = true;
String Mode = "Heating";
String Status = "Off";
bool Status_Change_Flag = false;
bool On = false;
int Setting = 0;
int Old_Setting = 0;
int Extra_Low_Current;
int Low_Current;
int Medium_Current;
int High_Current;
int Power_Current;
int Extra_Low_Previous;
int Low_Previous;
int Medium_Previous;
int High_Previous;
int Power_Previous;
int Fireplace_Temp;
bool Fireplace_Temp_Flag = false;
double Fireplace_Battery;
String FP_Temp_TimeStamp;
String FP_Battery_TimeStamp;
String Temp_String;
String Battery_String;
int Fan_TempF;
//Timer to read digital temp sensor every 3 seconds
Timer timer(3000, Read_Temp);
bool Read_Temp_Flag = false;
SYSTEM_THREAD(ENABLED);
timer.start();
pinMode(Extra_Low, INPUT);
pinMode(Low, INPUT);
pinMode(Medium, INPUT);
pinMode(High, INPUT);
pinMode(Power, INPUT);
Particle.subscribe("Fan_Command", Fan_Command, MY_DEVICES);
Particle.subscribe("Fireplace_Temp", Fireplace_Temp_Action, MY_DEVICES);
Particle.subscribe("Fireplace_Battery", Fireplace_Battery_Action, MY_DEVICES);
Particle.variable("Status", Status);
Particle.variable("Mode", Mode);
Particle.variable("Fireplace_Temp", Fireplace_Temp);
Particle.variable("Fireplace_Battery", Fireplace_Battery);
Particle.variable("FP_Temp_TimeStamp", FP_Temp_TimeStamp);
Particle.variable("FP_Battery_TimeStamp", FP_Battery_TimeStamp);
Particle.variable("Fan_Temp", Fan_TempF);
Time.zone(-5);
//Read the fan temp sensor
if (Read_Temp_Flag==true and sensor.read()) {
Fan_TempF = sensor.fahrenheit();
Read_Temp_Flag=false;
//Read all of the fan button pins to see if a button was pressed
Extra_Low_Current = digitalRead(Extra_Low);
Low_Current = digitalRead(Low);
Medium_Current = digitalRead(Medium);
High_Current = digitalRead(High);
Power_Current = digitalRead(Power);
//Series of if-statements to update fan settings and status based on button presses and current status
if (Extra_Low_Current == 0 and Extra_Low_Current != Extra_Low_Previous and On == true) {
Setting = 1;
Status = "Low-Low";
else if (Low_Current == 0 and Low_Current != Low_Previous and On == true) {
Setting = 2;
Status = "Low";
else if (Medium_Current == 0 and Medium_Current != Medium_Previous and On == true) {
Setting = 3;
Status = "Medium";
else if (High_Current == 0 and High_Current != High_Previous and On == true) {
Setting = 4;
Status = "High";
else if (Power_Current == 0 and Power_Current != Power_Previous and On == true) {
Setting = 0;
Status = "Off";
On = false;
else if (Power_Current == 0 and Power_Current != Power_Previous and On == false) {
Setting = 5;
Status = "High";
On = true;
//Update 'previous' button values to current values
Extra_Low_Previous = Extra_Low_Current;
Low_Previous = Low_Current;
Medium_Previous = Medium_Current;
High_Previous = High_Current;
Power_Previous = Power_Current;
//Heating Mode fan speed evaluation
if (Fireplace_Temp_Flag == true and Heating_Season == true) {
if (Fireplace_Temp < 100) {
Setting = 0;
else if (Fireplace_Temp >= 100 and Fireplace_Temp < 120) {
Setting = 1;
else if (Fireplace_Temp >= 120 and Fireplace_Temp < 140) {
Setting = 2;
else if (Fireplace_Temp >= 140) {
Setting = 3;
//Cooling Mode fan speed evaluation
if (Fireplace_Temp_Flag == true and Heating_Season == false) {
if ((Fireplace_Temp-Fan_TempF) < 5) {
Setting = 0;
else if ((Fireplace_Temp-Fan_TempF) >= 5 and (Fireplace_Temp-Fan_TempF) < 10) {
Setting = 1;
else if ((Fireplace_Temp-Fan_TempF) >= 10 and (Fireplace_Temp-Fan_TempF) < 15) {
Setting = 2;
else if ((Fireplace_Temp-Fan_TempF) >= 15 and (Fireplace_Temp-Fan_TempF) < 20) {
Setting = 3;
else if ((Fireplace_Temp-Fan_TempF) >= 20) {
Setting = 4;
//If-statement to check whether the setting changed, requiring a fan speed change
if (Setting != Old_Setting) {
Status_Change_Flag = true;
//If-statements to evaluate if a fan-speed change is needed
if (Status_Change_Flag == true) {
if (Setting == 0 and On == true) {
pinMode(Power, OUTPUT);
digitalWrite(Power, LOW);
delay(75);
On = false;
Status = "Off";
else if (Setting == 5 and On == false) {
delay(75);
On = true;
Status = "High";
else if (Setting == 1) {
if (On == false) {
delay(75);
On = true;
Status = "High";
delay(75);
pinMode(Extra_Low, OUTPUT);
digitalWrite(Extra_Low, LOW);
delay(75);
Status = "Low-Low";
else {
delay(75);
Status = "Low-Low";
else if (Setting == 2) {
if (On == false) {
delay(75);
On = true;
Status = "High";
delay(75);
pinMode(Low, OUTPUT);
digitalWrite(Low, LOW);
delay(75);
Status = "Low";
else {
delay(75);
Status = "Low";
else if (Setting == 3) {
if (On == false) {
delay(75);
On = true;
Status = "High";
delay(75);
pinMode(Medium, OUTPUT);
digitalWrite(Medium, LOW);
delay(75);
Status = "Medium";
else {
delay(75);
Status = "Medium";
else if (Setting == 4) {
if (On == false) {
delay(75);
On = true;
Status = "High";
else {
pinMode(High, OUTPUT);
digitalWrite(High, LOW);
delay(75);
Status = "High";
Old_Setting = Setting;
//Update variables based on commands published
void Fan_Command(const char *event, const char *data)
if (strcmp(data,"Off")==0) {
Setting = 0;
else if (strcmp(data,"On")==0) {
Setting = 5;
else if (strcmp(data,"1")==0) {
Setting = 1;
else if (strcmp(data,"2")==0) {
Setting = 2;
else if (strcmp(data,"3")==0) {
Setting = 3;
else if (strcmp(data,"4")==0) {
Setting = 4;
else if (strcmp(data,"Heating")==0) {
Mode = "Heating";
else if (strcmp(data,"Cooling")==0) {
Heating_Season = false;
Mode = "Cooling";
//Update variables and flags when fireplace temp sensor data published
void Fireplace_Temp_Action(const char *event, const char *data)
Temp_String = data;
Fireplace_Temp = Temp_String.toInt();
FP_Temp_TimeStamp = Time.timeStr();
Fireplace_Temp_Flag = true;
//Update variables when fireplace battery level data published
void Fireplace_Battery_Action(const char *event, const char *data)
Battery_String = data;
Fireplace_Battery = Battery_String.toInt();
FP_Battery_TimeStamp = Time.timeStr();
//Timer to set a flag true for reading the digital fan temp sensor
void Read_Temp()
Read_Temp_Flag = true;
