What I want to accomplish:
Hardware - Photon, Solar Panel, 10K Thermistor, Photon Power Shield
Desired behaviour:
Wake up ever 15 minutes, publish pool temperature (and other stuff to IFTTT), write temperature to Google sheets. Charge LiPO battery - Rinse and repeat
I’ve cobbled code and hardware from a few different information sources and have a working system (new to IOT). It reads temperature publishes and charges.
Problems:
- After I started using deep sleep (to conserve battery overnight) the particle inconsistently connects to the cloud and publishes data. Some hours I’ll get 4 readings - sometimes 1. I think this is a blocking issue, but not sure where to start.
- I have difficulty publish new code since the particle does it thing and then goes back to sleep. I tried a delay, but that seemed to be part of the blocking problem.
- I’m a coding hack new to IOT. I’d like my code to be as clean, efficient and fault tolerant as possible.
#include <PowerShield.h>
// Author: Gustavo Gonnet
// Contact: gusgonnet@gmail.com
// Project: https://www.hackster.io/gusgonnet/pool-temperature-monitor-5331f2
// License: Apache-2.0
// IO mapping
// A0 : pool_THERMISTOR
int _version = 1.2;
#include <math.h>
#include "application.h"
// Include the Powershield library
#include "PowerShield/PowerShield.h"
PowerShield batteryMonitor;
// this is the thermistor used
// https://amzn.to/2KmOIT4
// resistance at 25 degrees C
#define THERMISTORNOMINAL 10000
// temp. for nominal resistance (almost always 25 C)
#define TEMPERATURENOMINAL 25
// how many samples to take and average, more takes longer
// but measurement is 'smoother'
#define NUMSAMPLES 10
// The beta coefficient of the thermistor (usually 3000-4000)
#define BCOEFFICIENT 3950
// the value of the 'other' resistor
#define SERIESRESISTOR 10000
//measure the temperature every POOL_READ_INTERVAL msec
#define POOL_READ_INTERVAL 900000
unsigned long pool_interval = 0;
int samples[NUMSAMPLES];
int pool_THERMISTOR = A0;
//this is coming from http://www.instructables.com/id/Datalogging-with-Spark-Core-Google-Drive/?ALLSTEPS
char pool_temperature_str[64]; //String to store the sensor data
char pool_temperature_ifttt[64];
//by default, we'll display the temperature in degrees celsius, but if you prefer farenheit please set this to true
bool useFahrenheit = true;
//Get wifi signal strength
int rssi = 0;
Particle.publish("device starting", "Version: " + String(_version), 60, PRIVATE);
pool_interval = 0;
Particle.function("status", status);
pinMode(pool_THERMISTOR, INPUT);
//google sheets will get this variable
//the name of this varriable CANNOT be longer than 12 characters
//https://docs.particle.io/reference/firmware/photon/#particle-variable-
Particle.variable("pool_tmp", pool_temperature_str, STRING);
Particle.variable("pool_temp", pool_temperature_str, STRING);
Particle.variable("RSSI", &rssi, INT);
//Include the setp for power shield
// This essentially starts the I2C bus
batteryMonitor.begin();
// This sets up the fuel gauge
batteryMonitor.quickStart();
// Wait for it to settle down
delay(1000); //delay 1.0 second
//measure the temperature right away after a start and every POOL_READ_INTERVAL msec after that
// if( (millis() - pool_interval >= POOL_READ_INTERVAL) or (pool_interval==0) ) {
pool_temp();
pool_interval = millis();
rssi = WiFi.RSSI(); // Read wifi signal strength
Particle.publish("rssi", String(rssi), 60, PRIVATE); //Publish wifi signal to the cloud
float cellVoltage = batteryMonitor.getVCell(); // Read the volatge of the LiPo Battery
Particle.publish("ps-voltage", String(cellVoltage), 60, PRIVATE); // Publish Cell Voltage to cloud
float stateOfCharge = batteryMonitor.getSoC(); // Read the State of Charge of the LiPo
Particle.publish("ps-soc", String(stateOfCharge), 60, PRIVATE); // Publish State of Charge to Cloud
// delay(6000); // added to keep Particle awake to receive new code flashed over wi-fi
// System.sleep(SLEEP_MODE_DEEP, 840); // sleep time with above to get 15 minute intervals
System.sleep(SLEEP_MODE_DEEP, 900);
* Function Name : status
* Description : this function gets called for the sake of pushing the temperature to your phone
* Return : 0
int status(String args)
//this triggers a recipe in IFTTT
Particle.publish("pool_temp", pool_temperature_ifttt, 60, PRIVATE);
return 0;
* Function Name : pool_temp
* Description : read the value of the thermistor, convert it to degrees and store it in pool_temperature_str
* Return : 0
int pool_temp()
uint8_t i;
float average;
// take N samples in a row, with a slight delay
for (i=0; i< NUMSAMPLES; i++) {
samples[i] = analogRead(pool_THERMISTOR);
delay(10);
// average all the samples out
average = 0;
average += samples[i];
average /= NUMSAMPLES;
// convert the value to resistance
average = (4095 / average) - 1;
average = SERIESRESISTOR / average;
float steinhart;
steinhart = average / THERMISTORNOMINAL; // (R/Ro)
steinhart = log(steinhart); // ln(R/Ro)
steinhart /= BCOEFFICIENT; // 1/B * ln(R/Ro)
steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
steinhart = 1.0 / steinhart; // Invert
steinhart -= 273.15; // convert to C
// Convert Celsius to Fahrenheit - EXPERIMENTAL, so let me know if it works please - Gustavo.
// source: http://playground.arduino.cc/ComponentLib/Thermistor2#TheSimpleCode
// project source to let me know if this works: https://www.hackster.io/gusgonnet/pool-temperature-monitor-5331f2
if (useFahrenheit) {
steinhart = (steinhart * 9.0)/ 5.0 + 32.0;
char ascii[32];
int steinhart1 = (steinhart - (int)steinhart) * 100;
// for negative temperatures
steinhart1 = abs(steinhart1);
sprintf(ascii,"%0d.%d", (int)steinhart, steinhart1);
Particle.publish("pool_temp", ascii, 60, PRIVATE);
char tempInChar[32];
sprintf(tempInChar,"%0d.%d", (int)steinhart, steinhart1);
//Write temperature to string, google sheets will get this variable
sprintf(pool_temperature_str, "{\"t\":%s}", tempInChar);
//this variable will be published by function status()
sprintf(pool_temperature_ifttt, "%s", tempInChar);
return 0;
