Code issue i can not find
hello,
i calculate a ratio, and if the value change more than 3%, i publish it to google ( sub program ), and update the data last_ratio. ( last one saved )
for an unknown reason, the code is not working one way… only one test is working.
Any idea ?
what would be the best way / code to do this, meaning detect a value change more than xx %
thanks in advance.
Franck
//=== test if ratio changed ===========
 void ratio_change() {
   min_temp=last_ratio*0,97;
   if ( ratio < min_temp ) {
      pubgoogle;
      last_ratio=ratio;
      return;
   max_temp=last_ratio*1,03;
   if ( ratio > max_temp) {
       pubgoogle;
       last_ratio=ratio;
Are you sure this even compiles?
You are using the comma (,) where you’d need to use the decimal dot (.) in 0.97 & 1.03.
And pubgoogle; is not a function call.
You can write this slightly different
bool ration_change() {
  // when ratio is outside of interval
  if ( ratio < last_ratio * 0.97 || last_ratio * 1.03 < ratio ) {
    pubgoogle();
    last_ratio = ratio;
hello ScruffR,
thanks a lot for your help, what a stupid mistake a could not see… comma ( , . ).
i fixed it and it work.
i also like your all in one test.
The Pubgoogle() is a fonction that pushed data to google, using spark.publish, with delimiter, then I used cloud function to push data to big query.
see extract of the function.
 String text6=String(volt,0); // Vin monitoring without the . so divided by 100
 text0 = text1+';'+text2+';'+text3+';'+text4+';'+text5+';'+text6+';'+text7+';'+text8+';'+text9+';'+text10;
        Spark.publish("DATA ",text0,60,PRIVATE);
thanks a lot for your help.
"Spark" is ancient by now. You'd do well to update it to Particle, as it's written in the docs.
thank you,
i will update… as you can see it’s now a long time i am with particle …
thank you
