ClickButton library long pressed issue
I am having a problem with the long pressed function in the ClickButton library.
Test code:
#include "application.h"
#include "clickButton.h"
#include "SPI.h"
SYSTEM_THREAD(ENABLED);
SYSTEM_MODE(SEMI_AUTOMATIC);
// BUTTON define
#define EXTPIN D7
#define RUNPIN D3
// button define
ClickButton exitButton(EXTPIN, LOW, CLICKBTN_PULLUP);
ClickButton runButton(RUNPIN, LOW, CLICKBTN_PULLUP);
// Button results
int funcRunButtn = 0;
// setup() runs once, when the device is first turned on.
  // Put initialization like pinMode and begin functions here.
  // init serial
   WiFi.on();
   Particle.connect();
   pinMode(EXTPIN, INPUT);
   pinMode(RUNPIN, INPUT);
   // Setup button timers (all in milliseconds / ms)
     // (These are default if not set, but changeable for convenience)
     exitButton.debounceTime   = 20;   // Debounce timer in ms
     exitButton.multiclickTime = 250;  // Time limit for multi clicks
     exitButton.longClickTime  = 1000; // time until "held-down clicks" register
     runButton.debounceTime   = 20;   // Debounce timer in ms
     runButton.multiclickTime = 250;  // Time limit for multi clicks
     runButton.longClickTime  = 1000; // time until "held-down clicks" register
// loop() runs over and over again, as quickly as it can execute.
  // The core of your code will likely live here.
  // Update button state
      runButton.Update();
      // Save click codes in LEDfunction, as click codes are reset at next Update()
      if(runButton.clicks != 0) funcRunButtn = runButton.clicks;
      if(funcRunButtn == 1)
        Serial.println("Run BUTTON SINGLE click");
        LngButtonTest();
    funcRunButtn = 0;
    delay(5);
void LngButtonTest()
  bool isTestDone = false;
  int fExtButtn = 0;
  Serial.println("");
  Serial.println("Enter Long Button Test Function");
  Serial.println("");
  while (!isTestDone)
       exitButton.Update();
       if(exitButton.clicks != 0)
         fExtButtn = exitButton.clicks;
       if(fExtButtn == 1)
         Serial.println("EXIT BUTTON SINGLE click");
       if(fExtButtn == -1)
         Serial.println("EXIT BUTTON SINGLE LONG click");
         isTestDone = true;
      fExtButtn = 0;
      delay(5);
Output:
Opening serial monitor for com port: "COM3"
Run BUTTON SINGLE click                     <---  I pressed  the run button
EXIT BUTTON SINGLE LONG click        <---- I pressed the exit button long pressed
Run BUTTON SINGLE click                    <---- I pressed the run button again
EXIT BUTTON SINGLE LONG click    <<<< problem, automatic exit without pressed exit long button
It look like exitButton.Update(); still get the previous value (-1) in this case, button did not get reset even no pressed action. If I press the run button the third time, the problem does not happen.
Any one have encounter this before or any pointers? Thanks
Problem solved:
When I put a check loop until !-1 in front of while(!isTestDone), the problem when away. I believe I am triggering the exitbutton to soon since there is a debounce timer. When I trigger the button before the timer runs out that when I see the automatic execution.
