I’ve got a problem with functioning the push button.
The code is the same and simple as other push button code.
int buttonPin1 = D4; // the number of the pushbutton pin
int buttonPin2 = D5; // the number of the pushbutton pin
int redPin = D0;
int greenPin = D1;
int bluePin = D2;
int buttonState1 = 0; // variable for reading the pushbutton status
int buttonState2 = 0;
int speakerPin = D3;
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
// declare pin 9 to be an output:
pinMode(speakerPin, OUTPUT);
beep(50);
beep(50);
beep(50);
delay(1000);
buttonState1 = digitalRead(buttonPin1);
buttonState2 = digitalRead(buttonPin2);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState1 == HIGH) {
// turn LED on:
setColor(255, 0, 0); // red
delay(1000);
beep(1000);
if (buttonState2 == HIGH) {
// turn LED on:
setColor(0, 255, 255); // aqua
delay(1000);
beep(1000);
else {
// turn LED off:
setColor(0, 0, 0);
void beep(unsigned char delayms){
analogWrite(speakerPin, 20);
delay(delayms);
analogWrite(speakerPin, 0);
delay(delayms);
void setColor(int red, int green, int blue)
analogWrite(redPin, red);
analogWrite(greenPin, green);
analogWrite(bluePin, blue);
I have two buttons, one RGB LED, and one buzzer.
The system should be run according to the code, but it does not follow the code.
Supposedly when button1 is pressed red light will appear and when button2 is press aqua light will appear. But the system run without the IF/ELSE function. it just lights up the red and aqua color without me pushing the buttons.
So, is there any guide that I can use, to use the push button and make it follow my instruction?
Are you sure when you press the button its state goes high, and not the other way around ?
If not, print the state of both buttons in that loop to verify what you think is happening is actually happening.
Still, print the button states before your if statements. You need to confirm they are actually changing state.
Also, your beep(1000); value is larger than your “void beep(unsigned char delayms)” can accept.
unsigned char is only 255.
I didn’t mean print in that way. Keep it simple at first to verify the buttons are wired correctly. When using INPUT_PULLUP, you will need to wire your button with one end going to D5 and the other to gnd.
#define BUTTON D5
int val;
pinMode(BUTTON, INPUT_PULLUP);
Serial.begin(115200);
Serial.printf("System Ready...\n");
val = digitalRead(BUTTON);
Serial.printf("Button Value is: %d\n", val);
delay(250);
@Syerlac, not sure why you want to reinvent button push detection since your code doesn’t even address debounce. I suggest you look at proven button libraries available on the web IDE such as “debounce” and “clickButton”. One is interrupt driven, the other is polled and both will serve you well.
Yup, there are libraries that will save you some (a lot) work, but you still should understand how to do things properly and if the wiring isn’t done correctly the best of libraries won’t help much.
Sir, I’ve tried your suggestion using the ClickButton.
Yes, the button functioning well. But when I re-code the code like below,
#include <clickButton.h>
int redPin = D0;
int greenPin = D1;
int bluePin = D2;
// variables will change:
ClickButton button1(buttonPin1, LOW, CLICKBTN_PULLUP);
// Button results
int functionB1 = 0;
pinMode(D4, INPUT_PULLUP);
// Setup button timers (all in milliseconds / ms)
// (These are default if not set, but changeable for convenience)
button1.debounceTime = 20; // Debounce timer in ms
button1.multiclickTime = 250; // Time limit for multi clicks
button1.longClickTime = 1000; // time until "held-down clicks" register
beep(50);
beep(50);
beep(50);
delay(1000);
// Update button state
button1.Update();
// Save click codes in LEDfunction, as click codes are reset at next Update()
if(button1.clicks != 0) functionB1 = button1.clicks;
if(functionB1 == 1) Particle.publish("SINGLE click");
delay(1000);
if(functionB1 == 2) Particle.publish("DOUBLE click");
setColor(0, 255, 0); // green
delay(1000);
functionB1 = 0;
delay(5);
analogWrite(speakerPin, 20); // Almost any value can be used except 0 and 255
// experiment to get the best tone
delay(delayms); // wait for a delayms ms
analogWrite(speakerPin, 0); // 0 turns it off
It still not functions when I push the button. But the LED is running without me pushing the button.
