Changing to Wire1 from Wire
Hi Folks,
I am using an electron and an INA219 sensor to measure the voltage of a battery. I have already used up the standard SDA and SCL pins for another use on the electron, so instead I am using pins C4 and C5, the alternate SDA and SCL pins.
I am having trouble figuring out how to change the library for the INA219 to use Wire1 (which is what I am assuming I have to do) instead of Wire.
-Do I have to change all references of wire to wire1? Or just the wire.begin?
-I am a little confused on how to modify a library and then use the library as changed. I copied and pasted to new tabs in the project but I am getting errors now. (I get “multiple definitions” errors)
Thanks as always for the guidance!
This is what I did:
#include <adafruit-ina219_GB.h>
Adafruit_INA219 ina219;
void setup(void)
  uint32_t currentFrequency;
  Serial.begin(115200);
  Serial.println("Hello!");
  // Initialize the INA219.
  // By default the initialization will use the largest range (32V, 2A).  However
  // you can call a setCalibration function to change this range (see comments).
  ina219.begin();
  // To use a slightly lower 32V, 1A range (higher precision on amps):
  //ina219.setCalibration_32V_1A();
  // Or to use a lower 16V, 400mA range (higher precision on volts and amps):
  //ina219.setCalibration_16V_400mA();
  Serial.println("Measuring voltage and current with INA219 ...");
void loop(void)
  float shuntvoltage = 0;
  float busvoltage = 0;
  float current_mA = 0;
  float loadvoltage = 0;
  shuntvoltage = ina219.getShuntVoltage_mV();
  busvoltage = ina219.getBusVoltage_V();
  current_mA = ina219.getCurrent_mA();
  loadvoltage = busvoltage + (shuntvoltage / 1000);
  Serial.print("Bus Voltage:   "); Serial.print(busvoltage); Serial.println(" V");
  Serial.print("Shunt Voltage: "); Serial.print(shuntvoltage); Serial.println(" mV");
  Serial.print("Load Voltage:  "); Serial.print(loadvoltage); Serial.println(" V");
  Serial.print("Current:       "); Serial.print(current_mA); Serial.println(" mA");
  Serial.println("");
  delay(2000);
and then I made the .cpp and .h files as follows:
    @file     Adafruit_INA219.cpp
    @author   K.Townsend (Adafruit Industries)
	@license  BSD (see license.txt)
	Driver for the INA219 current sensor
	This is a library for the Adafruit INA219 breakout
	----> https://www.adafruit.com/products/???
	Adafruit invests time and resources providing this open source code,
	please support Adafruit and open-source hardware by purchasing
	products from Adafruit!
	@section  HISTORY
    v1.0 - First release
#if defined (SPARK)
  #include "application.h"
#else
  #if defined(ARDUINO) && ARDUINO >= 100
    #include "Arduino.h"
  #else
    #include "WProgram.h"
  #endif
  // here could follow some of the includes only needed on Arduino
  // see bellow
#endif
#include "adafruit-ina219.h"
    @brief  Sends a single command byte over I2C
void Adafruit_INA219::wireWriteRegister (uint8_t reg, uint16_t value)
  Wire1.beginTransmission(ina219_i2caddr);
  #if defined (SPARK)
      Wire1.write(reg);                       // Register
      Wire1.write((value >> 8) & 0xFF);       // Upper 8-bits
      Wire1.write(value & 0xFF);              // Lower 8-bits
  #else
    #if ARDUINO >= 100
    #else
      Wire.send(reg);                        // Register
      Wire1.send(value >> 8);                 // Upper 8-bits
      Wire1.send(value & 0xFF);               // Lower 8-bits
    #endif
  #endif
  Wire1.endTransmission();
    @brief  Reads a 16 bit values over I2C
void Adafruit_INA219::wireReadRegister(uint8_t reg, uint16_t *value)
    #if defined (SPARK)
      Wire1.write(reg);
    #else
      #if ARDUINO >= 100
      #else
        Wire1.send(reg);                        // Register
      #endif
    #endif
  delay(1); // Max 12-bit conversion time is 586us per sample
  Wire1.requestFrom(ina219_i2caddr, (uint8_t)2);
  #if defined (SPARK)
      *value = ((Wire1.read() << 8) | Wire1.read());
  #else
    #if ARDUINO >= 100
      // Shift values to create properly formed integer
    #else
      *value = ((Wire1.receive() << 8) | Wire1.receive());
    #endif
  #endif
    @brief  Configures to INA219 to be able to measure up to 32V and 2A
            of current.  Each unit of current corresponds to 100uA, and
            each unit of power corresponds to 2mW. Counter overflow
            occurs at 3.2A.
    @note   These calculations assume a 0.1 ohm resistor is present
void Adafruit_INA219::setCalibration_32V_2A(void)
  // By default we use a pretty huge range for the input voltage,
  // which probably isn't the most appropriate choice for system
  // that don't use a lot of power.  But all of the calculations
  // are shown below if you want to change the settings.  You will
  // also need to change any relevant register settings, such as
  // setting the VBUS_MAX to 16V instead of 32V, etc.
  // VBUS_MAX = 32V             (Assumes 32V, can also be set to 16V)
  // VSHUNT_MAX = 0.32          (Assumes Gain 8, 320mV, can also be 0.16, 0.08, 0.04)
  // RSHUNT = 0.1               (Resistor value in ohms)
  // 1. Determine max possible current
  // MaxPossible_I = VSHUNT_MAX / RSHUNT
  // MaxPossible_I = 3.2A
  // 2. Determine max expected current
  // MaxExpected_I = 2.0A
  // 3. Calculate possible range of LSBs (Min = 15-bit, Max = 12-bit)
  // MinimumLSB = MaxExpected_I/32767
  // MinimumLSB = 0.000061              (61uA per bit)
  // MaximumLSB = MaxExpected_I/4096
  // MaximumLSB = 0,000488              (488uA per bit)
  // 4. Choose an LSB between the min and max values
  //    (Preferrably a roundish number close to MinLSB)
  // CurrentLSB = 0.0001 (100uA per bit)
  // 5. Compute the calibration register
  // Cal = trunc (0.04096 / (Current_LSB * RSHUNT))
  // Cal = 4096 (0x1000)
  ina219_calValue = 4096;
  // 6. Calculate the power LSB
  // PowerLSB = 20 * CurrentLSB
  // PowerLSB = 0.002 (2mW per bit)
  // 7. Compute the maximum current and shunt voltage values before overflow
  // Max_Current = Current_LSB * 32767
  // Max_Current = 3.2767A before overflow
  // If Max_Current > Max_Possible_I then
  //    Max_Current_Before_Overflow = MaxPossible_I
  // Else
  //    Max_Current_Before_Overflow = Max_Current
  // End If
  // Max_ShuntVoltage = Max_Current_Before_Overflow * RSHUNT
  // Max_ShuntVoltage = 0.32V
  // If Max_ShuntVoltage >= VSHUNT_MAX
  //    Max_ShuntVoltage_Before_Overflow = VSHUNT_MAX
  // Else
  //    Max_ShuntVoltage_Before_Overflow = Max_ShuntVoltage
  // End If
  // 8. Compute the Maximum Power
  // MaximumPower = Max_Current_Before_Overflow * VBUS_MAX
  // MaximumPower = 3.2 * 32V
  // MaximumPower = 102.4W
  // Set multipliers to convert raw current/power values
  ina219_currentDivider_mA = 10;  // Current LSB = 100uA per bit (1000/100 = 10)
  ina219_powerDivider_mW = 2;     // Power LSB = 1mW per bit (2/1)
  // Set Calibration register to 'Cal' calculated above
  wireWriteRegister(INA219_REG_CALIBRATION, ina219_calValue);
  // Set Config register to take into account the settings above
  uint16_t config = INA219_CONFIG_BVOLTAGERANGE_32V |
                    INA219_CONFIG_GAIN_8_320MV |
                    INA219_CONFIG_BADCRES_12BIT |
                    INA219_CONFIG_SADCRES_12BIT_1S_532US |
                    INA219_CONFIG_MODE_SANDBVOLT_CONTINUOUS;
  wireWriteRegister(INA219_REG_CONFIG, config);
    @brief  Configures to INA219 to be able to measure up to 32V and 1A
            of current.  Each unit of current corresponds to 40uA, and each
            unit of power corresponds to 800�W. Counter overflow occurs at
            1.3A.
void Adafruit_INA219::setCalibration_32V_1A(void)
  // MaxExpected_I = 1.0A
  // MinimumLSB = 0.0000305             (30.5�A per bit)
  // MaximumLSB = 0.000244              (244�A per bit)
  // CurrentLSB = 0.0000400 (40�A per bit)
  // Cal = 10240 (0x2800)
  ina219_calValue = 10240;
  // PowerLSB = 0.0008 (800�W per bit)
  // Max_Current = 1.31068A before overflow
  // Else
  // End If
  // ... In this case, we're good though since Max_Current is less than MaxPossible_I
  // Max_ShuntVoltage = 0.131068V
  // Else
  // End If
  // MaximumPower = 1.31068 * 32V
  // MaximumPower = 41.94176W
  ina219_currentDivider_mA = 25;      // Current LSB = 40uA per bit (1000/40 = 25)
  ina219_powerDivider_mW = 1;         // Power LSB = 800�W per bit
void Adafruit_INA219::setCalibration_16V_400mA(void) {
  // Calibration which uses the highest precision for
  // current measurement (0.1mA), at the expense of
  // only supporting 16V at 400mA max.
  // VBUS_MAX = 16V
  // VSHUNT_MAX = 0.04          (Assumes Gain 1, 40mV)
  // MaxPossible_I = 0.4A
  // MaxExpected_I = 0.4A
  // MinimumLSB = 0.0000122              (12uA per bit)
  // MaximumLSB = 0.0000977              (98uA per bit)
  // CurrentLSB = 0.00005 (50uA per bit)
  // Cal = 8192 (0x2000)
  ina219_calValue = 8192;
  // PowerLSB = 0.001 (1mW per bit)
  // Max_Current = 1.63835A before overflow
  // Else
  // End If
  // Max_Current_Before_Overflow = 0.4
  // Max_ShuntVoltage = 0.04V
  // Else
  // End If
  // Max_ShuntVoltage_Before_Overflow = 0.04V
  // MaximumPower = 0.4 * 16V
  // MaximumPower = 6.4W
  ina219_currentDivider_mA = 20;  // Current LSB = 50uA per bit (1000/50 = 20)
  ina219_powerDivider_mW = 1;     // Power LSB = 1mW per bit
  uint16_t config = INA219_CONFIG_BVOLTAGERANGE_16V |
                    INA219_CONFIG_GAIN_1_40MV |
    @brief  Instantiates a new INA219 class
Adafruit_INA219::Adafruit_INA219(uint8_t addr) {
  ina219_i2caddr = addr;
  ina219_currentDivider_mA = 0;
  ina219_powerDivider_mW = 0;
    @brief  Setups the HW (defaults to 32V and 2A for calibration values)
void Adafruit_INA219::begin(uint8_t addr) {
  begin();
void Adafruit_INA219::begin(void) {
  Wire1.begin();
  // Set chip to large range config values to start
  setCalibration_32V_2A();
    @brief  Gets the raw bus voltage (16-bit signed integer, so +-32767)
int16_t Adafruit_INA219::getBusVoltage_raw() {
  uint16_t value;
  wireReadRegister(INA219_REG_BUSVOLTAGE, &value);
  // Shift to the right 3 to drop CNVR and OVF and multiply by LSB
  return (int16_t)((value >> 3) * 4);
    @brief  Gets the raw shunt voltage (16-bit signed integer, so +-32767)
int16_t Adafruit_INA219::getShuntVoltage_raw() {
  uint16_t value;
  wireReadRegister(INA219_REG_SHUNTVOLTAGE, &value);
  return (int16_t)value;
    @brief  Gets the raw current value (16-bit signed integer, so +-32767)
int16_t Adafruit_INA219::getCurrent_raw() {
  uint16_t value;
  // Sometimes a sharp load will reset the INA219, which will
  // reset the cal register, meaning CURRENT and POWER will
  // not be available ... avoid this by always setting a cal
  // value even if it's an unfortunate extra step
  // Now we can safely read the CURRENT register!
  wireReadRegister(INA219_REG_CURRENT, &value);
    @brief  Gets the shunt voltage in mV (so +-327mV)
float Adafruit_INA219::getShuntVoltage_mV() {
  int16_t value;
  value = getShuntVoltage_raw();
  return value * 0.01;
    @brief  Gets the shunt voltage in volts
float Adafruit_INA219::getBusVoltage_V() {
  int16_t value = getBusVoltage_raw();
  return value * 0.001;
    @brief  Gets the current value in mA, taking into account the
            config settings and current LSB
float Adafruit_INA219::getCurrent_mA() {
  float valueDec = getCurrent_raw();
  valueDec /= ina219_currentDivider_mA;
  return valueDec;
Nevermind! I got it –
had to remove the library that I had originally included, the INA_219.
Then had to change the reference in my custom CPP to the .h file to my newly named .h file. Works great now!
Thanks.
I2C is a bus protocol so you can connect multiple devices to the same pins as long the devices have seperate I2C addresses.
Thanks, Scruff - but was already using those pins for a different device that was not I2C and changing all that would have been a big project. Using the Wire1 on the alternate pins works great.
