I am working with NFC over I2C and I am running into issues with the size of BUFFER_LENGTH in the I2C TwoWire setup.
My NFC P2P library needs 44 bytes in order to send/recieve data from Android Beam. I was wondering if I can change BUFFER_LENGTH to 44 without anything breaking…? I want to use I2C instead of SPI so I can attach to an interrupt instead of polling.
I just want to make sure that this will work before I set up my machine to build the custom firmware.
