I need to change the 3rd party APN credentials on a couple of Borons that have been shipped to another country. I already have the devices claimed to my account prior to shipping.
The user wants to use a different service provider.
What is the best way to go about this?
Would it be possible to connect the Borons(in DFU mode) to a remote pc and I upload the firmware to alter the credentials through particle cli?
Just a thought.
Otherwise the Borons would need to be shipped back, which is something I prefer to avoid.
This should help you out - https://support.particle.io/hc/en-us/articles/360039741113-3rd-party-SIM-cards
Instructions on how to set it is included.
Thank you @no1089.
I have already set the Birons to use Surfroam 3rd party sim prior to shipping.
The user needs to use a different provider and different APN settings.
This obviously requires to be setup via particle cli again.
I was asking if there is a way to use particle cli from a remote pc, is this even possible?
Have the user connect the Boron via USB and enter dfu mode, then hoping to remotely access his pc so I can run particle cli setup from my side.
You could load an app with the new APN:
#include "Particle.h"
#include "dct.h"
SYSTEM_MODE(SEMI_AUTOMATIC);
Cellular.setActiveSim(EXTERNAL_SIM);
Cellular.setCredentials("epc.tmobile.com");
// This clears the setup done flag on brand new devices so it won't stay in listening mode
const uint8_t val = 0x01;
dct_write_app_data(&val, DCT_SETUP_DONE_OFFSET, 1);
// This is just so you know the operation is complete
pinMode(D7, OUTPUT);
digitalWrite(D7, HIGH);
That should do it
If you still have connectivity, you can add it to an OTA, but be careful that you don’t make a mistake and have the device fall offline.
The end-user can also flash a new binary via the CLI using particle flash --usb newAPN.bin for example.
Teamviewer and the CLI installed on the remote PC should work too
So I can flash the above code(with correct APN credentials), insert new sim card, then it will connect to the cloud to flash new code?
