While doing some tests to better understand the behavior of networking function calls with
SYSTEM_THREAD(ENABLED), I encountered this unexpected behavior. If I call Cellular.disconnect() and then call Cellular.connect(), the Electron will not connect until it hits a timeout and turns the modem off and then back on. This process takes around 6 minutes. If instead I turn the modem all the way off and on before calling Cellular.connect() it connects very quickly (19 seconds). This behavior is consistent across any SYSTEM_MODE or SYSTEM_THREAD.
What is the intended purpose of Cellular.disconnect()? It doesn’t appear to have a functional use without also using Cellular.off().
Serial Output:
Connected to Particle Cloud
TESTING CELLULAR DISCONNECT INCLUDING TURNING CELLULAR OFF...
Particle.disconnect() returned after 0 millis
Disconnecting from Particle Cloud...
Took 523 millis to disconnect
Disconnected from Particle Cloud
Cellular.disconnect() returned after 0 millis
Took 1 millis to disconnect
Cellular.off() returned after 0 millis
Network powering off...
Network off
Took 6310 millis to turn off
Cellular.on() returned after 0 millis
Network powering on...
Network on
Took 3351 millis to turn on
Cellular.connect() returned after 0 millis
Connecting to network...
Took 18631 millis to connect
Connected to network
Particle.connect() returned after 0 millis
Connecting to Particle Cloud...
Took 368 millis to connect
TESTING CELLULAR DISCONNECT WITHOUT TURNING CELLULAR OFF...
Took 280 millis to disconnect
Network off
Network on
Took 344730 millis to connect
Took 358 millis to connect
My test code:
#include "Particle.h"
SYSTEM_THREAD(ENABLED); // Enable system threading
SYSTEM_MODE(AUTOMATIC); // Allow Particle to manage it's own connectivity
#if Wiring_Cellular
// Set your 3rd-party SIM APN here
// https://docs.particle.io/reference/firmware/electron/#setcredentials-
STARTUP(cellular_credentials_set("hologram", "", "", NULL));
// Cell indicator Config
CellularSignal sig;
int strength;
// 60 seconds chosen since hologram UDP timeout is estimated at around 180 seconds but in practice worked best at 60
const int keepAliveInterval = 20; // keepAlive interval in seconds
#endif
// Used for both WiFi and Cell
int rssi;
String signal_strength;
bool network_status_local = false;
uint32_t time_start;
void cloud_status_handler(system_event_t event, int param)
if (param == cloud_status_connecting)
Serial.println("Connecting to Particle Cloud...");
else if (param == cloud_status_connected)
// init the keepAlive interval to maintain connection to Particle cloud
#if Wiring_Cellular
Particle.keepAlive(keepAliveInterval);
#endif
Serial.println("Connected to Particle Cloud");
else if (param == cloud_status_disconnecting)
Serial.println("Disconnecting from Particle Cloud...");
else if (param == cloud_status_disconnected)
Serial.println("Disconnected from Particle Cloud");
void network_status_handler(system_event_t event, int param)
if (param == network_status_connecting)
Serial.println("Connecting to network...");
else if (param == network_status_connected)
Serial.println("Connected to network");
else if (param == network_status_off)
Serial.println("Network off");
else if (param == network_status_on)
Serial.println("Network on");
network_status_local = true;
else if (param == network_status_powering_on)
Serial.println("Network powering on...");
else if (param == network_status_powering_off)
Serial.println("Network powering off...");
bool waitCloudDisconnect() { return !Particle.connected(); }
bool waitCellDisconnect() { return !Cellular.ready(); }
bool waitCellOff() { return !network_status_local; }
bool waitCellOn() { return network_status_local; }
/* This function is called once at start up ----------------------------------*/
System.on(cloud_status, cloud_status_handler);
System.on(network_status, network_status_handler);
pinMode(A0, OUTPUT);
digitalWrite(A0, LOW);
delay(10000);
Serial.println("PERFORMING INITIAL SETUP");
// TURN ON CELLULAR
time_start = millis();
Cellular.on();
Serial.println("Cellular.on() returned after " + String(millis() - time_start) + " millis");
waitUntil(waitCellOn);
Serial.println("Took " + String(millis() - time_start) + " millis to turn on");
delay(1000);
// CONNECT TO CELLULAR NETWORK
Cellular.connect();
Serial.println("Cellular.connect() returned after " + String(millis() - time_start) + " millis");
waitUntil(Cellular.ready);
Serial.println("Took " + String(millis() - time_start) + " millis to connect");
delay(1000);
// CONNECT TO PARTICLE CLOUD
Particle.connect();
Serial.println("Particle.disconnect() returned after " + String(millis() - time_start) + " millis");
waitUntil(Particle.connected);
delay(1000);
Serial.println("");
Serial.println("");
Serial.println("Setup Complete");
Serial.println("");
Serial.println("");
/* This function loops forever --------------------------------------------*/
// now let's kick - for a kick to be valid it must be
// at least 100ns
ATOMIC_BLOCK() // we'll consider this timing critical
digitalWrite(A0, HIGH); // rising edge to begin DONE signal detection on TPL5010
delayMicroseconds(10); // wait 10x minimum time of 100ns
digitalWrite(A0, LOW); // bring line back to wait for next kick
if (Particle.connected())
Serial.println("");
Serial.println("");
Serial.println("TESTING CELLULAR DISCONNECT INCLUDING TURNING CELLULAR OFF...");
// DISCONNECT FROM PARTICLE CLOUD
Particle.disconnect();
waitUntil(waitCloudDisconnect);
Serial.println("Took " + String(millis() - time_start) + " millis to disconnect");
delay(1000);
// DISCONNECT FROM CELLULAR NETWORK
Cellular.disconnect();
Serial.println("Cellular.disconnect() returned after " + String(millis() - time_start) + " millis");
waitUntil(waitCellDisconnect);
delay(1000);
// TURN OFF CELLULAR
Cellular.off();
Serial.println("Cellular.off() returned after " + String(millis() - time_start) + " millis");
waitUntil(waitCellOff);
Serial.println("Took " + String(millis() - time_start) + " millis to turn off");
delay(1000);
// TURN ON CELLULAR
Cellular.on();
delay(1000);
Cellular.connect();
delay(1000);
Particle.connect();
Serial.println("Particle.connect() returned after " + String(millis() - time_start) + " millis");
delay(1000);
Serial.println("");
Serial.println("");
// at least 100ns
Serial.println("TESTING CELLULAR DISCONNECT WITHOUT TURNING CELLULAR OFF...");
delay(1000);
delay(1000);
Cellular.connect();
delay(1000);
Particle.connect();
delay(1000);
Serial.println("");
Serial.println("");
// at least 100ns
delay(5000);
