[14:37:04] (base) ➜ ~ particle tachyon setup
Cannot find module 'execa'
Require stack:
- /usr/local/lib/node_modules/particle-cli/src/lib/qdl.js
- /usr/local/lib/node_modules/particle-cli/src/cmd/flash.js
- /usr/local/lib/node_modules/particle-cli/src/cmd/setup-tachyon.js
- /usr/local/lib/node_modules/particle-cli/src/cli/tachyon.js
- /usr/local/lib/node_modules/particle-cli/src/cli/index.js
- /usr/local/lib/node_modules/particle-cli/src/app/cli.js
- /usr/local/lib/node_modules/particle-cli/src/index.js
Error above - guidance appreciated.
Note: particle version is 3.39.0 installed.
