Can we use the onboard AM1805 on the Muons?
It'll be great if we make the Muon HIBERNATE sleep and we are able to wake it up with the AM1805 after few minutes (say 5 minutes).
Is this possible? Thanks
@gusgonnet, looking at the Muon schematics, yes, the required wiring is there with the EN going to the ENABLE pin of the PM-BAT module. As such, I suspect you can use @rickkas7 AB1805_RK library.
