I ran a test and the interrupt counts seem to be working for me in the scenario below.
I connected a frequency generator to pins D2 and D3. It was set for 1000 Hz.
I then ran this firmware on the Photon 2 (it’s a P2 on the Photon 2, so they should behave the same).
#include "Particle.h"
SYSTEM_THREAD(ENABLED);
SYSTEM_MODE(SEMI_AUTOMATIC);
SerialLogHandler logHandler;
void isrD2();
void isrD3();
std::atomic<uint32_t> counterD2;
std::atomic<uint32_t> counterD3;
Particle.connect();
counterD2.store(0, std::memory_order_relaxed);
pinMode(D2, INPUT_PULLUP);
attachInterrupt(D2, isrD2, FALLING);
counterD3.store(0, std::memory_order_relaxed);
pinMode(D3, INPUT_PULLUP);
attachInterrupt(D3, isrD3, FALLING);
static unsigned long lastCheck = 0;
if (millis() - lastCheck >= 1000) {
lastCheck = millis();
uint32_t tempD2 = counterD2.fetch_and(0, std::memory_order_relaxed);
uint32_t tempD3 = counterD3.fetch_and(0, std::memory_order_relaxed);
Log.info("D2=%lu D3=%lu", tempD2, tempD3);
void isrD2() {
// This increments the value atomically. Even if the ISR triggers
// while we're resetting the value from loop, the count will
// not be lost.
counterD2.fetch_add(1, std::memory_order_relaxed);
void isrD3() {
counterD3.fetch_add(1, std::memory_order_relaxed);
And this is the USB serial output:
0000027084 [app] INFO: D2=1000 D3=1000
0000028084 [app] INFO: D2=1000 D3=1000
0000029084 [app] INFO: D2=1000 D3=1000
0000030084 [app] INFO: D2=1000 D3=1000
0000031084 [app] INFO: D2=1000 D3=1000
0000032084 [app] INFO: D2=1000 D3=1000
0000033084 [app] INFO: D2=1000 D3=1000
0000034084 [app] INFO: D2=1000 D3=1000
0000035084 [app] INFO: D2=1000 D3=1000
0000036084 [app] INFO: D2=1000 D3=1000
0000037084 [app] INFO: D2=1000 D3=1000
0000038084 [app] INFO: D2=1000 D3=1000
0000039084 [app] INFO: D2=999 D3=999
0000040084 [app] INFO: D2=1000 D3=1000
0000041084 [app] INFO: D2=1000 D3=1000
0000042084 [app] INFO: D2=1000 D3=1000
0000043084 [app] INFO: D2=1000 D3=1000
0000044084 [app] INFO: D2=1000 D3=1000
0000045084 [app] INFO: D2=1000 D3=1000
0000046084 [app] INFO: D2=1000 D3=1000
0000047084 [app] INFO: D2=1000 D3=1000
0000048084 [app] INFO: D2=1000 D3=1000
0000049084 [app] INFO: D2=1000 D3=1000
0000050084 [app] INFO: D2=1000 D3=1000
0000051084 [app] INFO: D2=1000 D3=1000
0000052084 [app] INFO: D2=999 D3=999
0000053084 [app] INFO: D2=1000 D3=1000
0000054084 [app] INFO: D2=1001 D3=1001
0000055084 [app] INFO: D2=999 D3=999
0000056084 [app] INFO: D2=1000 D3=1000
0000057084 [app] INFO: D2=1000 D3=1000
0000058084 [app] INFO: D2=1000 D3=1000
0000059084 [app] INFO: D2=1000 D3=1000
0000060084 [app] INFO: D2=1000 D3=1000
0000061084 [app] INFO: D2=1000 D3=1000
It’s not exactly 1000 on all logs because the logging is done out of the loop thread with the cloud connection active, so it can be off by a little bit, but the counts seem to be equal.
It’s actually possible for the counts to differ if something else disables interrupts, or there’s a thread swap in between the two fetch_and calls.
That’s also a good way to structure counters in an ISR that are interrupt safe without having to disable interrupts.
