Can I change WiFi credentials without going into listening mode/DFU mode?
While designing the board for our prototype, we forgot to connect the SETUP pin (please, don’t ask why, it’s kind of embarrasing), so we’re basically stuck with only a RESET jumper. The next generation will of course also have a SETUP jumper, but for now we have to do without (only the first few prototypes).
Is it possible to add multiple WiFi networks without changing into listening mode? If not, is there a way to change the firmware so the WiFi credentials will already be included? If so, where do we add the credentials? We are using the P1 chip and we didn’t forget to add a JTag connector, so we should be able to flash the firmware.
@itd24, take a look at the documentation here:
https://docs.particle.io/reference/firmware/photon/#wifi-setcredentials-
:smiley:
I honestly don’t know, how I could miss that. Thank you :slight_smile:
