Callback Issue when encapsulating a Class in a Singleton
Hi all,
I am using the following library GitHub - sparkfun/SparkFun_Swarm_Satellite_Arduino_Library: An Arduino library to enable communications with the Swarm M138 satellite modem
I have created a singleton to control all swarm activity. In my singleton I am trying to setup a callback.
mySwarm.setTransmitDataCallback(&printMessageSent);
I am getting the following error:
argument of type "void (swarm::*)(const int16_t *rssi_sat, const int16_t *snr, const int16_t *fdev, const uint64_t *msg_id)" is incompatible with parameter of type "void (*)(const int16_t *rssi_sat, const int16_t *snr, const int16_t *fdev, const uint64_t *msg_id)"
This is the setTransmitDataCallback from the sparkfun swarm lib above:
void setTransmitDataCallback(void (*swarmTransmitDataCallback)(const int16_t *rssi_sat, const int16_t *snr, const int16_t *fdev, const uint64_t *msg_id));
I have a feeling that this might be the same issue as described in the topic below
What would be the best way to get around this? I'm being held back by my knowledge of callbacks and pointers I think.
Thanks in advance,
I believe the problem is that the callback function takes a C/C++ function, not a class member.
This is easily solved by making your callback function in your class static. Then have the static function recover the singleton class instance pointer and call a non-static method that does the actual work.
You can tell because the argument passed in is void (swarm::*)( which indicates a class member. The required argument is void (*)( which is a static class member or plain C/C++ function (not in a class).
Hi Rick,
Thanks for the reply. I'm just trying to understand your response.
So I create a new dummy static function
static void getSingletonPointerCallNonStatic(const int16_t *rssi_sat, const int16_t *snr, const int16_t *fdev, const uint64_t *msg_id);
which will be used to call the actual function
void printMessageSent(const int16_t *rssi_sat, const int16_t *snr, const int16_t *fdev, const uint64_t *msg_id);
As per your suggestion I need to recover the singleton class instance pointer.
swarm::instance()
and then call my original callback
printMessageSent()
Apologies my knowledge is poor here, should it be something like
swarm::instance()->printMessageSent()
How do i call the pointer of the singleton swarm::instance().
Am I stumbling in the right direction?
Here's an example that may help:
.h file
#ifndef __MYCLASS_H
#define __MYCLASS_H
#include "Particle.h"
 * This class is a singleton; you do not create one as a global, on the stack, or with new.
 * From global application setup you must call:
 * MyClass::instance().setup();
 * From global application loop you must call:
 * MyClass::instance().loop();
class MyClass {
public:
     * @brief Gets the singleton instance of this class, allocating it if necessary
     * Use MyClass::instance() to instantiate the singleton.
    static MyClass &instance();
     * @brief Perform setup operations; call this from global application setup()
     * You typically use MyClass::instance().setup();
    void setup();
     * @brief Perform application loop operations; call this from global application loop()
     * You typically use MyClass::instance().loop();
    void loop();
    static void printMessageSentStatic(const int16_t *rssi_sat, const int16_t *snr, const int16_t *fdev, const uint64_t *msg_id);
protected:
     * @brief The constructor is protected because the class is a singleton
    MyClass();
     * @brief The destructor is protected because the class is a singleton and cannot be deleted
    virtual ~MyClass();
     * This class is a singleton and cannot be copied
    MyClass(const MyClass&) = delete;
    MyClass& operator=(const MyClass&) = delete;
     * @brief Singleton instance of this class
     * The object pointer to this class is stored here. It's NULL at system boot.
    static MyClass *_instance;
#endif  /* __MYCLASS_H */
.cpp file
#include "MyClass.h"
MyClass *MyClass::_instance;
// [static]
MyClass &MyClass::instance() {
    if (!_instance) {
        _instance = new MyClass();
    return *_instance;
MyClass::MyClass() {
MyClass::~MyClass() {
void MyClass::setup() {
void MyClass::loop() {
    // Put your code to run during the application thread loop here
void MyClass::printMessageSent(const int16_t *rssi_sat, const int16_t *snr, const int16_t *fdev, const uint64_t *msg_id) {
// static
void MyClass::printMessageSentStatic(const int16_t *rssi_sat, const int16_t *snr, const int16_t *fdev, const uint64_t *msg_id) {
    instance().printMessageSent(rssi_sat, snr, fdev, msg_id);
Ok perfect, that's great. Thanks a million
Just for my own understanding, the instance() is the singleton class instance pointer? I'm assuming I could also use swarm::instance(), but I don't need to because I'm within that singleton anyway?
Yes, but the static member does not know its own instance pointer, so it needs to be stored somewhere.
The technique in my class, allocating the class instance from instance() is the recommended method. It prevents a race condition, and eliminates issues with prohibited calls from global object constructors.
If you allocate your class as a global variable, you can just save the global pointer in _instance from the constructor using:
YourClass::YourClass() {
  _instance = this;
