barskey
1
I want to register a class method as the callback function for Mesh.subscribe, like you can using Particle.subscribe. I have tried using this syntax:
Mesh.subscribe("some_event", &Subscriber::handler, this);
But it gives an error in the compiler. If I change it to Particle.subscribe it compiles fine.
Why isn’t the class method callback available for Mesh.subscribe? Or more importantly, is there a workaround I could try?
ScruffR
2
Because it wasn't implemented yet, I'd say.
You could use a static method.
barskey
3
Can you help with the syntax? I have tried declaring in the header:
static void handleInput(const char *event, const char *data);
And the method:
void PCTrigger::handleInput(const char *event, const char *data)
// My method
Calling Mesh.subscribe from the constructor:
Mesh.subscribe("trigger/" + _hexid, &PCTrigger::handleInput, this);
Gives the error:
no matching function for call to 'spark::MeshClass::subscribe(StringSumHelper&, void (*)(const char*, const char*), PCTrigger*)'
EDIT:
Never mind. I realize that I would use the callback without the class reference, like this:
Mesh.subscribe("trigger/" + _hexid, handleInput);
Compiles fine.
