Building an app that used to work on a Spark Core
Hi - I am having trouble with an application I wrote for a “Spark Core”. I had built this application a couple of years ago and need to make a change and it will no longer compile. I’ll include the raw output from the compile below. I actually needed to remove some text from the build and it tells me that it will APP_FLASH when it used to build and fit with no issue. Any help would be most appreciated. This app is including Temboo.h and liquid-cyrstal-spi.h. Thanks in advance!
Compiler output (I had to trim a few lines to make it fit):
Processing  emergencyalert.ino
Checking library Temboo...
Checking library liquid-crystal-spi...
Installing library liquid-crystal-spi 0.0.1 to lib/liquid-crystal-spi ...
Installing library Temboo 1.2.8 to lib/Temboo ...
Library liquid-crystal-spi 0.0.1 installed.
Library Temboo 1.2.8 installed.
make -C ../newlib_nano
make[1]: Entering directory '/firmware/newlib_nano'
make[1]: Nothing to be done for 'all'.
make[1]: Leaving directory '/firmware/newlib_nano'
make -C ../user
make[1]: Entering directory '/firmware/user'
Building cpp file: src/emergencyalert.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-0-ltosrc/
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -DSPARK_PLATFORM -DFLASHEE_EEPROM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=1.4.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../dynalib/inc -Isrc -I./libraries -Ilib/Temboo/src -Ilib/liquid-crystal-spi/src -I. -MD -MP -MF ../build/target/user/platform-0-ltosrc/emergencyalert.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=CC3000 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DMODULE_VERSION=1401 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -std=gnu++14 -c -o ../build/target/user/platform-0-ltosrc/emergencyalert.o src/emergencyalert.cpp
In file included from emergencyalert.ino:2:0:
lib/Temboo/src/Temboo.h:29:0: warning: "pgm_read_byte" redefined
 #define pgm_read_byte(address_short) (*address_short)
In file included from ./inc/application.h:92:0,
                 from src/emergencyalert.cpp:1:
../wiring/inc/spark_wiring_arduino.h:60:0: note: this is the location of the previous definition
 #define pgm_read_byte(x)      (*(x))
lib/Temboo/src/Temboo.h:31:0: warning: "PSTR" redefined
 #define PSTR
../wiring/inc/spark_wiring_arduino.h:56:0: note: this is the location of the previous definition
 #define PSTR(x) (x)
In file included from /usr/local/gcc-arm-embedded/arm-none-eabi/include/c++/5.3.1/backward/strstream:50:0,
                 from lib/Temboo/src/Temboo.h:71,
/usr/local/gcc-arm-embedded/arm-none-eabi/include/c++/5.3.1/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated. [-Wcpp]
 #warning \
In file included from lib/Temboo/src/ChoreoInputSet.h:26:0,
                 from lib/Temboo/src/Temboo.h:78,
lib/Temboo/src/TembooGlobal.h:29:0: warning: "pgm_read_byte" redefined
 #define pgm_read_byte(address) (*address)
lib/Temboo/src/Temboo.h:29:0: note: this is the location of the previous definition
emergencyalert.ino: In function 'void loop()':
emergencyalert.ino:370:47: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
emergencyalert.ino:382:5: warning: 'Spark' is deprecated: Spark is now Particle. [-Wdeprecated-declarations]
In file included from ../wiring/inc/spark_wiring.h:51:0,
                 from ./inc/application.h:40,
../wiring/inc/spark_wiring_cloud.h:412:19: note: declared here
 extern CloudClass Spark __attribute__((deprecated("Spark is now Particle.")));
emergencyalert.ino:606:126: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
emergencyalert.ino:348:14: warning: unused variable 'FireEvents' [-Wunused-variable]
emergencyalert.ino:349:14: warning: unused variable 'TempEvents' [-Wunused-variable]
Building cpp file: lib/Temboo/src/TembooSession.cpp
mkdir -p ../build/target/user/platform-0-ltoTemboo/src/
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -DSPARK_PLATFORM -DFLASHEE_EEPROM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=1.4.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../dynalib/inc -Isrc -I./libraries -Ilib/Temboo/src -Ilib/liquid-crystal-spi/src -I. -MD -MP -MF ../build/target/user/platform-0-ltoTemboo/src/TembooSession.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=CC3000 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DMODULE_VERSION=1401 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -std=gnu++14 -c -o ../build/target/user/platform-0-ltoTemboo/src/TembooSession.o lib/Temboo/src/TembooSession.cpp
In file included from lib/Temboo/src/TembooSession.h:26:0,
                 from lib/Temboo/src/TembooSession.cpp:34:
                 from lib/Temboo/src/TembooSession.cpp:28:
lib/Temboo/src/TembooGlobal.h:33:0: warning: "PSTR" redefined
 #define PSTR
 #define PSTR(x) (x)
Building cpp file: lib/Temboo/src/ChoreoPreset.cpp
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -DSPARK_PLATFORM -DFLASHEE_EEPROM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=1.4.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../dynalib/inc -Isrc -I./libraries -Ilib/Temboo/src -Ilib/liquid-crystal-spi/src -I. -MD -MP -MF ../build/target/user/platform-0-ltoTemboo/src/ChoreoPreset.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=CC3000 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DMODULE_VERSION=1401 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -std=gnu++14 -c -o ../build/target/user/platform-0-ltoTemboo/src/ChoreoPreset.o lib/Temboo/src/ChoreoPreset.cpp
Building cpp file: lib/Temboo/src/Temboo.cpp
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -DSPARK_PLATFORM -DFLASHEE_EEPROM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=1.4.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../dynalib/inc -Isrc -I./libraries -Ilib/Temboo/src -Ilib/liquid-crystal-spi/src -I. -MD -MP -MF ../build/target/user/platform-0-ltoTemboo/src/Temboo.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=CC3000 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DMODULE_VERSION=1401 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -std=gnu++14 -c -o ../build/target/user/platform-0-ltoTemboo/src/Temboo.o lib/Temboo/src/Temboo.cpp
                 from lib/Temboo/src/Temboo.cpp:87:
 #warning \
In file included from lib/Temboo/src/Temboo.cpp:87:0:
lib/Temboo/src/Temboo.cpp: In member function 'int TembooChoreo::run(IPAddress, uint16_t)':
lib/Temboo/src/Temboo.cpp:282:39: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
         if (!m_client.find("HTTP/1.1 ")) {
lib/Temboo/src/Temboo.cpp:299:47: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
             if (m_client.find("x-temboo-time:")) {
lib/Temboo/src/Temboo.cpp:320:42: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
     if (!m_client.find("\x0D\x0A\x0D\x0A")) {
Building cpp file: lib/Temboo/src/ChoreoInput.cpp
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -DSPARK_PLATFORM -DFLASHEE_EEPROM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=1.4.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../dynalib/inc -Isrc -I./libraries -Ilib/Temboo/src -Ilib/liquid-crystal-spi/src -I. -MD -MP -MF ../build/target/user/platform-0-ltoTemboo/src/ChoreoInput.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=CC3000 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DMODULE_VERSION=1401 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -std=gnu++14 -c -o ../build/target/user/platform-0-ltoTemboo/src/ChoreoInput.o lib/Temboo/src/ChoreoInput.cpp
Building cpp file: lib/Temboo/src/ChoreoInputFormatter.cpp
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -DSPARK_PLATFORM -DFLASHEE_EEPROM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=1.4.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../dynalib/inc -Isrc -I./libraries -Ilib/Temboo/src -Ilib/liquid-crystal-spi/src -I. -MD -MP -MF ../build/target/user/platform-0-ltoTemboo/src/ChoreoInputFormatter.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=CC3000 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DMODULE_VERSION=1401 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -std=gnu++14 -c -o ../build/target/user/platform-0-ltoTemboo/src/ChoreoInputFormatter.o lib/Temboo/src/ChoreoInputFormatter.cpp
Building cpp file: lib/Temboo/src/BaseFormatter.cpp
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -DSPARK_PLATFORM -DFLASHEE_EEPROM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=1.4.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../dynalib/inc -Isrc -I./libraries -Ilib/Temboo/src -Ilib/liquid-crystal-spi/src -I. -MD -MP -MF ../build/target/user/platform-0-ltoTemboo/src/BaseFormatter.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=CC3000 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DMODULE_VERSION=1401 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -std=gnu++14 -c -o ../build/target/user/platform-0-ltoTemboo/src/BaseFormatter.o lib/Temboo/src/BaseFormatter.cpp
Building cpp file: lib/Temboo/src/tmbhmac.cpp
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -DSPARK_PLATFORM -DFLASHEE_EEPROM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=1.4.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../dynalib/inc -Isrc -I./libraries -Ilib/Temboo/src -Ilib/liquid-crystal-spi/src -I. -MD -MP -MF ../build/target/user/platform-0-ltoTemboo/src/tmbhmac.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=CC3000 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DMODULE_VERSION=1401 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -std=gnu++14 -c -o ../build/target/user/platform-0-ltoTemboo/src/tmbhmac.o lib/Temboo/src/tmbhmac.cpp
Building cpp file: lib/Temboo/src/ChoreoInputSet.cpp
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -DSPARK_PLATFORM -DFLASHEE_EEPROM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=1.4.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../dynalib/inc -Isrc -I./libraries -Ilib/Temboo/src -Ilib/liquid-crystal-spi/src -I. -MD -MP -MF ../build/target/user/platform-0-ltoTemboo/src/ChoreoInputSet.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=CC3000 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DMODULE_VERSION=1401 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -std=gnu++14 -c -o ../build/target/user/platform-0-ltoTemboo/src/ChoreoInputSet.o lib/Temboo/src/ChoreoInputSet.cpp
Building cpp file: lib/liquid-crystal-spi/src/liquid-crystal-spi.cpp
mkdir -p ../build/target/user/platform-0-ltoliquid-crystal-spi/src/
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -DSPARK_PLATFORM -DFLASHEE_EEPROM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=1.4.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../dynalib/inc -Isrc -I./libraries -Ilib/Temboo/src -Ilib/liquid-crystal-spi/src -I. -MD -MP -MF ../build/target/user/platform-0-ltoliquid-crystal-spi/src/liquid-crystal-spi.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=CC3000 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DMODULE_VERSION=1401 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -fcheck-new -std=gnu++14 -c -o ../build/target/user/platform-0-ltoliquid-crystal-spi/src/liquid-crystal-spi.o lib/liquid-crystal-spi/src/liquid-crystal-spi.cpp
Building target: ../build/target/user/platform-0-ltolibuser.a
Invoking: ARM GCC Archiver
arm-none-eabi-gcc-ar -cr ../build/target/user/platform-0-ltolibuser.a ../build/target/user/platform-0-ltosrc/emergencyalert.o ../build/target/user/platform-0-ltoTemboo/src/TembooSession.o ../build/target/user/platform-0-ltoTemboo/src/ChoreoPreset.o ../build/target/user/platform-0-ltoTemboo/src/Temboo.o ../build/target/user/platform-0-ltoTemboo/src/ChoreoOutputSet.o ../build/target/user/platform-0-ltoTemboo/src/ChoreoPresetFormatter.o ../build/target/user/platform-0-ltoTemboo/src/TembooGlobal.o ../build/target/user/platform-0-ltoTemboo/src/ChoreoInput.o ../build/target/user/platform-0-ltoTemboo/src/ChoreoInputFormatter.o ../build/target/user/platform-0-ltoTemboo/src/BaseFormatter.o ../build/target/user/platform-0-ltoTemboo/src/tmbhmac.o ../build/target/user/platform-0-ltoTemboo/src/ChoreoInputSet.o ../build/target/user/platform-0-ltoTemboo/src/tmbmd5.o ../build/target/user/platform-0-ltoTemboo/src/ChoreoOutput.o ../build/target/user/platform-0-ltoTemboo/src/ChoreoOutputFormatter.o ../build/target/user/platform-0-ltoTemboo/src/DataFormatter.o ../build/target/user/platform-0-ltoliquid-crystal-spi/src/liquid-crystal-spi.o
Building target: target/workspace.elf
Invoking: ARM GCC C++ Linker
mkdir -p target/
arm-none-eabi-g++ -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DMBEDTLS_CONFIG_FILE="<mbedtls_config.h>" -DSYSTEM_VERSION_STRING=1.4.0 -DRELEASE_BUILD -Werror -I../user/inc -I../wiring/inc -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../crypto/inc -I../third_party/mbedtls/mbedtls/include -I../dynalib/inc -I. -MD -MP -MF target/workspace.elf.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DMODULE_VERSION=1401 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE target/obj/./src/module_info.o  target/obj/startup/startup_stm32f10x_md.o --output target/workspace.elf -nostartfiles -Xlinker --gc-sections -flto -Os -fuse-linker-plugin -Tlinker_stm32f10x_md_dfu.ld -L../build/arm/linker --specs=nano.specs -lc -lnosys -u _printf_float -Wl,-Map,target/workspace.map  -L../build/target/user/platform-0-lto -L../build/target/wiring/platform-0-lto/ -L../build/target/system/platform-0-lto/ -L../build/target/services/platform-0-lto/ -L../build/target/communication/platform-0-lto-prod-0/ -L../build/target/hal/platform-0-lto/ -L../build/target/platform/platform-0-lto/ -L../build/target/wiring_globals/platform-0-lto/ -L../build/target/crypto/platform-0-lto/ -L../build/target/newlib_nano/platform-0-lto -L../build/target/miniz/platform-0-lto -L../build/target/nanopb/platform-0-lto -L../build/target/mbedtls/platform-0-lto -L../build/arm/linker -Wl,--whole-archive -lnewlib_nano -luser -lwiring -lhal -lsystem -lservices -lcommunication -lplatform -lwiring_globals -lcrypto -lminiz -lnanopb -lmbedtls -Wl,--no-whole-archive
/usr/local/gcc-arm-embedded/bin/../lib/gcc/arm-none-eabi/5.3.1/../../../../arm-none-eabi/bin/ld: target/workspace.elf section `.text' will not fit in region `APP_FLASH'
/usr/local/gcc-arm-embedded/bin/../lib/gcc/arm-none-eabi/5.3.1/../../../../arm-none-eabi/bin/ld: region `APP_FLASH' overflowed by 10576 bytes
../build/module.mk:232: recipe for target 'target/workspace.elf' failed
make: *** [target/workspace.elf] Error 1
Wow - welcome back but that is a huge amount to absorb - maybe share the code and folks can comment ?
Hi -
Code is below. Phone numbers changed to protect the innocent :). Keep in mind this code used to build and is running in a spark core right now. I just needed to change some of the numbers as people have moved. Any help would be great.
//#include "application.h"
#include <liquid-crystal-spi.h>
#include <Temboo.h>
As it seems you are targeting 1.4.0 but the more recent device OS versions have considerably grown, leaving very little space for the application firmware on Spark Core.
You should either transition to Photon/Argon or opt for some older device OS version.
But for your code, there are quite a few portions that could be written to safe RAM and with transfering some data (i.e. phone numbers, user names, …) into EEPROM may help save flash space and rid you of the need to adapt your code when any of the numbers changes.
How would you suggest to get the values into EEPROM to start? Would you suggest just writing an application that loads EEPROM, then loading my app? I’d rather not add code to use the serial console in the main app as it would serve no additional purpose. Also, I’m not sure just moving the names and numbers into EEPROM would make enough room to make it work.
Do you think rebuilding it for a Photon would work? They are pin compatible correct?
Evan
I'd rather have some function to add and update entries in EEPROM remotely.
e.g. via a Particle.function() or a Particle.subscribe() handler.
For the most part they are - the only "hard" consideration is the use of A3 and A6 (aka as DAC) which are not 5V tolerant on the Photon.
There also is no 3*3 pin on the Photon - that was substituted for Vbat.
True, this would win you 127bytes the most unless you'd access it directly and not via the EEPROM emulation.
And streamlining your code would maybe win you the 1-2 KB, but you seem to be 10K short.
I'd definetly opt for a Photon.
Thank you for taking the time out to analyze and respond to my questions. I’ll move the code to a Photon. Dissapointed that I cannot rebuild the code which was working to fit back into the original part.
Thanks again for your help.
Evan
It would. As I said, you can target an older device OS version.
How do I change to an older device OS version? (I am building from the web interface)
When you go in Web IDE to this drawer image
You will see your device with a shevron image next to it.
Click that to expand and there you will get this
Open the drop down list and select another target version.
