BRN404X with device OS 6.2.1 & 5.5.0 - 8X and highly fluctuation power consumption
So my use case is battery operated Boron's, I was getting ready to deploy a new version of software to the fleet (using 6.1.0) however, just did a quick check and looks like some change occurred in device OS or maybe Modem Firmware that causes inconsistent power consumption. Typical power consumption in the 70 mA range running tinker on 6.2.1. Yikes!
As you can see in this post, back in Sept 2023 running device OS 5.5.0 I was observing only ~9 mA current when connected and awake. This was stable and consistent. This was awesome for my use case!!!
However, now running device OS 6.2.1, running tinker, with the device on a breadboard (nothing else connected). I am observing nearly constant power consumption of nearly 70 mA. 8X increase.. This was a brand new boron out of the box.
The extremely strange behavior is I've noticed if I call a particle function the power consumption will "stabilize" at about 27 mA and then it'll even drop down to 5mA (Even lower than what I observed back in Sept 2023) although anywhere from 10 seconds to a few minutes it'll then jump back up to the 70 mA range until another particle function is called.
I know... hard to describe in words. Here is a video demonstrating this behavior:
I am able to repeat this in Device OS 5.5.0 and Device OS 6.2.1. I would of thought going back to Device OS 5.5.0 would of produced identical results as I did back in Sept 2023. But that's not the case.
From what I can tell... something changed in how the device handshakes with the towers or the cloud between Sept 2023 and Today. When I call a function, the device gets "in sync" and handshakes properly, even consumes less power then back then. But then quickly gets "out of Sync" or for some other reason then jumps up until a function is called again. Maybe different firmware on the modem? Different behavior with the cloud? I would love to understand what is causing this.
Following
Thanks for raising this - will bug engineering and a few folks to test.
Hi @jgskarda I have a BRN404X running Tinker on device OS 6.2.1 that is getting normal power readings. Do you have any other devices you can try? Maybe a different battery?
Give it some time... the severity of the problem seems to fluctuate/act different now vs 5 minutes from now. As of this morning, I am having a tougher time to reproduce the issue using the exact same hardware, battery, device OS, as I did last night, etc. Last night it was nearly every 30 seconds. Today it's taking a lot longer to observe. I already tried different batteries and 3 differen particle BRN404X devices (board V1.50, and board V1.5.1) I saw it happen twice so far this morning but more like every 5-10 minutes or more. Notice here, it's stable and is about 5.5mA. Similar to your trend:
And then just 5 minutes later it now spiked (right hand side of the trend)
This is a zoomed in view:
Definitely seems to be something with the cellular modem. I did some testing with Sleep with cellular on and it randomly spiked up to 70mA constant in the middle of it's sleep cycle with cellular on:
Is it possible it's related to the cell tower itself or some strange RF behavior with my cell tower it connects to?
Side note: I just ordered a Nordic Power Profiler Kit as well as clearly that provides a lot more capability over this current ranger open source thing I am currently using.
Hi @jgskarda I was able to reproduce the high current condition after some time of letting the device run. Our engineering team will be looking into this.
@ericpietrowicz - It's great to hear you are able to reproduce this issue and it's not just me loosing my mind. :exploding_head:
If there is anything I can do to help assist in testing or collecting data from different scenarios from this side please let me know. With having you and the engineering team able to reproduce the scenario, I'm now hopeful the fine team at Particle can pinpoint the cause and determine how to remedy it! It definitely seems strange. Please let me know once you learn something new.
Jeff, this is a LONG Shot..... but exactly 6 years ago (to the day!) I recorded the same thing with Borons. Turned out that the Device Under Test would start communicating with the Cloud 4 seconds after a different Boron on my "test" Particle account sent a publish.
There were no Particle.variables, Subscribes, Functions, etc.
Here's my summary a couple days later. Physical proximity wasn't related, as mentioned later in the thread.
My suspicion was something on the Cloud Side changed on 12/18/2018 which happened to be during my test, so I had specific documentation of the results pre and post.
It might be worth a few minutes to perform your same test on a temp Particle Account with only 1 Boron? Like I said, it's a long shot :wink:
I'm willing to try anything so we can learn more together. I just revitalized an old Particle Account I had, created a new "product" and added a brand new BRN404X out of the box to that product. So from the particle cloud side, it's like I'm two completely separate customers. This account only has 1 single product and 1 single device in that product.
@Rftop This seems crazy... but you might be on to something. I'm at 20 minutes in and so far it's been consistent/expected power from the isolated device. Typically at 6mA with spikes with an average of 10.5 mA. At no point in time, did it spike to 70mA for any measurable duration of time:
This has been stable like this for roughly 20 minutes now (darn Current ranger only keeps 7-8 minutes of data I guess):
With dedicated particle Console Account - with 1 product with only 1 device in the product: Unable to observe the issue
With Product based "Growth" account and hundreds of devices in the same product: Issue observed within 2 minutes
Observing for longer durations of time, it seems to come/go with no apparent pattern. All other devices in the fleet publish at a 5 minute interval at the top of the hour. this isn't aligned to that either.
Here is the current test setup:
Boron 1: Brand New out of the box, V1.5.1 of hardware, running tinker Device OS 6.1.1 in a "Product" with several hundred devices in the same "product". Observes the spike in current consumption.
Boron 2: Brand New out of the box, V1.5.1 of hardware (Same shipment as boron above), running tinker Device OS 6.1.1 in it's own isolated particle account and isolated product with only having this 1 device in the product. Unable to reproduce the spike in current consumption.
@ericpietrowicz, @no1089 - Is there something here you want me to try?
  • Just keep testing the isolated boron in it's own product to see if it ever can be replicated there? Maybe it's just a fluke?
  • Move a device from the isolated product where it's not replicated to the Growth account product and see if it's replicated?
  • Move a device from the growth product where it's observed into it's own product, does it go away?
  • Add 1 additional boron to the isolated product, then 2, then 3, etc. and see where the issue starts?
  • Disable web hooks in the growth product to determine impact?
  • Capture some sort of debug log files? (I'd have to rig up some special USB cable to measure current through the USB cable but doable).
  • Try different Device OS
I'm open to trying whatever you think would help!
So continuing my tests... As I outlined above:
Experiment #1: Just keep testing the isolated boron claimed to it's own account, and it's own product. I.e. 1 device in 1 product with only 1 product in the account. Determine if the issue can be repeated or not.
Test Setup: Boron #2, new out of the box, running Device OS 6.1.1 and tinker on a bread board using current ranger to measure power consumption. Device claimed to an isolated account, with 1 product and 1 device in the product.
Results: A new out of the box boron sitting in it's own product, was able to go 1 consecutive hour with 0 observations of the spike in current.
Next test: If I move the device from the isolated account into a product with hundreds of other devices, without changing firmware or device OS, will the behavior change. I'll post the results of this test next.
Here are detailed trends from my current ranger of this first test performed:
Detailed trends are broken out into 7-8 minute intervals for roughly 1 continuous hour of operation:
Minute: 18:56 - 19:04
Minute: 19:04 – 19:13
Minute: 19:13 – 19:20
Minute: 19:20 – 19:27
Minute: 19:27 – 19:34
Minute: 19:34 – 19:41
Minute: 19:38 - 19:45
Minute: 19:45 - 19:52
Minute: 19:52 - 20:00:
Experiment #2: If I move the device from the isolated account into a product with hundreds of other devices, without changing firmware or device OS, will the behavior change. I'll post the results of this test next.
Test Setup: Boron #2, new out of the box, running Device OS 6.1.1 and tinker on a bread board using current ranger to measure power consumption. Device claimed to an isolated account, with 1 product and 1 device in the product. (Identical Boron used in Experiment #1). The device was not powered off or reset between Experiment #1 to #2. I simply unclaimed it from one account, claimed it to the other to a product with hundreds of device in the product. Same firmware exact firmware and setup.
Results:
20:00 - 20:20: No issue observed
@20:20 - Injected Particle Function Call (DigitalRead(D7)):
20:20 - 20:30 - No issue observed
@20:30: Powered off the device for 5 seconds and powered back on to induce a new cloud connection.
20:30 - 20:35: Change in current profile is immediately observed (a lot more short spikes):
Average current draw seems to steadily increase and become more "noisy" with a steadily increasing average current. Occasional multiple second long sustained spikes in to 70-80 mA range. Average current increased from ~11mA --> 21mA due to additional spikes/noise.
20:35 - 20:40:
@20:46: Injected a Particle Function Call (DigitalRead())
Observed a noticeable shift in the current profile. Generally more stable and lower average current after calling the function. (21 ma --> 15 mA). Although had 1 observed "spike". Still not back to baseline of 11 mA.
@20:56:00 Injected a power off/on again. Noticeable upward shift in the current profile again:
21:17:30 - Moved the device back into the individual product with 1 device in the product, powered off. So far it's behaving the same as it did with the product with 100s of devices:
Not sure what to think at this point. I'm not noticing the extended durations of 70 mA constant power, but then again, it's different and more current on average the what I started with in Experiment #1. I'm power it off for 25 minutes (maybe for the night) to make sure the keep alive times out and see if that does anything:
Are you able to sync logs with the current draw? Trace logs would be best, and should show what the device is receiving from the cloud.
(I'm a little dumfounded as to what's going on)
As Eric mentioned, we've escalated this to engineering to take a look as well.
@no1089 - Certainly, happy to do that as well. I'll try and rig up a USB cable so I can run the power of the USB cable through the current ranger while having the data lines in tact to do both current draw measurements alongside, serial logging to the PC. I'll try and post results here in the next few hours.
In the meantime, I did want to update. Last night, I moved both Boron's that were new out of the box used for this test, back to the isolated account/product and let them sit turned off overnight. This morning, I still observed the 70 mA constant draw on one of the devices while breathing for 5 minutes constant. This indicates it's not related to the number of devices in a product OR the device or cloud has yet "forgot" about the device not being in the product. This happened within the first 5 minutes after a device reset. I'll try to re-create this but include the logs with it here shortly.
What's frustrating/hard to diagnose this is it seemingly comes/goes or becomes worse or better for no apparent reason at different times of the day. Hopefully we can learn something in the device logs.
I sure appreciate the attention and escalating to engineering!
More to come...
It's certainly very strange behaviour - the TX/RX pins are a useful way to get logs from the device without influencing power. You just need to specify serial1 when setting up the logs.
Thank you for the effort here! I'm away from home and can't test a 404X here in ZA, otherwise I'd be jumping in as well.
Oh nice, that’ll be easier than hacking a cable. I’ll give that a try shortly.
@no1089, @ericpietrowicz - Good news and bad news... good news is I was able to replicate it while capturing log files. Unfortunately, nothing is written out to the log when the high current scenario occurs.
Here is a video of my test setup once the scenario presents itself: Sorry for rotating the video when showing the log. I did include it farther below.
Not sure if I mentioned this, but I also was able to replicate this when the device is in a sleep with network state. When the high current state occurs, the MCU continues to sleep.
So it seems like it's something specific on the cellular modem itself and
One open question: What changed between Sept 2023 and now that also resulted in a further reduction in the steady state/connected current from ~ 9mA --> 5 mA when working correctly. Was there some additional functionality or mode we are putting the cellular modem in that was added behind the scenes at Particle in an attempt to further reduce current draw less than 9 mA? Maybe this had some sort of unintended side affect that we are just now observing?
Let me know what else you'd like me to test/try.
Here are further details of what's provided in the video:
Here is the snippet of the log file. The high current condition started occurring about 5 minutes after the reboot sometime between 0000020787 and 0000372541. The logging was completely silent during this time.
Notice, there is then the digitalRead command in the log at 0000372541. This aligns with me clicking the digital read function in the video.
0000020602 [ncp.at] TRACE: < OK
0000020602 [comm.coap] TRACE: Sending CoAP message
0000020603 [comm.coap] TRACE: CON 2.05 size=199 token=02 id=10
0000020786 [comm.coap] TRACE: Received CoAP message
0000020787 [comm.coap] TRACE: ACK 0.00 size=4 token= id=10
{High current scenario started during this lull period with nothing being written out to the log}
0000372540 [comm.coap] TRACE: Received CoAP message
0000372541 [comm.coap] TRACE: CON POST /f/digitalRead? size=20 token=03 id=64125
0000372541 [comm.coap] TRACE: Sending CoAP message
0000372542 [comm.coap] TRACE: ACK 0.00 size=4 token= id=64125
0000372543 [app] INFO: digitalRead command received:
0000372544 [comm.coap] TRACE: Sending CoAP message
0000372544 [comm.coap] TRACE: CON 2.04 size=10 token=03 id=11
0000372700 [comm.coap] TRACE: Received CoAP message
0000372700 [comm.coap] TRACE: ACK 0.00 size=4 token= id=11
Here is the full log file from when the device first powered up:
0000002052 [net.pppncp] TRACE: NCP event 3
0000002053 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000002053 [system.nm] TRACE: Interface 4 power state changed: UP
0000002054 [ncp.client] TRACE: Modem powered on
0000002054 [ncp.client] TRACE: Setting UART voltage translator state 1
0000002154 [ncp.client] TRACE: Setting UART voltage translator state 0
0000002254 [ncp.client] TRACE: Setting UART voltage translator state 1
0000003256 [ncp.at] TRACE: > AT
0000003616 [ncp.at] TRACE: < OK
0000003616 [ncp.client] TRACE: NCP ready to accept AT commands
0000003617 [ncp.at] TRACE: > AT
0000003619 [ncp.at] TRACE: < OK
0000003620 [ncp.at] TRACE: > ATI9
0000003622 [ncp.at] TRACE: < 03.15,A00.01
0000003622 [ncp.at] TRACE: < OK
0000003622 [ncp.client] TRACE: App firmware: 1
0000003623 [ncp.at] TRACE: > AT+UGPIOC?
0000003626 [ncp.at] TRACE: < +UGPIOC:
0000003626 [ncp.at] TRACE: < 16,255
0000003627 [ncp.at] TRACE: < 19,255
0000003627 [ncp.at] TRACE: < 23,0
0000003628 [ncp.at] TRACE: < 24,255
0000003628 [ncp.at] TRACE: < 25,255
0000003629 [ncp.at] TRACE: < 33,255
0000003629 [ncp.at] TRACE: < 42,255
0000003630 [ncp.at] TRACE: < 46,255
0000003630 [ncp.at] TRACE: < OK
0000003631 [ncp.at] TRACE: > AT+UGPIOR=23
0000003634 [ncp.at] TRACE: < +UGPIOR: 23,1
0000003634 [ncp.at] TRACE: < OK
0000003635 [ncp.client] INFO: Using internal SIM card
0000003635 [ncp.at] TRACE: > AT+CPIN?
0000003638 [ncp.at] TRACE: < ERROR
0000004637 [ncp.at] TRACE: > AT+CPIN?
0000004640 [ncp.at] TRACE: < +CPIN: READY
0000004640 [ncp.at] TRACE: < OK
0000004641 [ncp.at] TRACE: > AT+CCID
0000005035 [ncp.at] TRACE: < +CCID: 89883070000037636055
0000005035 [ncp.at] TRACE: < OK
0000005036 [ncp.at] TRACE: > AT+IFC?
0000005039 [ncp.at] TRACE: < +IFC: 2,2
0000005039 [ncp.at] TRACE: < OK
0000005040 [ncp.at] TRACE: > AT+IFC=2,2
0000005042 [ncp.at] TRACE: < OK
0000005042 [ncp.at] TRACE: > AT
0000005044 [ncp.at] TRACE: < OK
0000005045 [ncp.at] TRACE: > AT+IPR=460800
0000005048 [ncp.at] TRACE: < OK
0000006048 [ncp.at] TRACE: > AT
0000006051 [ncp.at] TRACE: < OK
0000006051 [ncp.at] TRACE: > AT+CCID
0000006092 [ncp.at] TRACE: < +CCID: 89883070000037636055
0000006092 [ncp.at] TRACE: < OK
0000006093 [ncp.at] TRACE: > AT+UMNOPROF?
0000006096 [ncp.at] TRACE: < +UMNOPROF: 100
0000006097 [ncp.at] TRACE: < OK
0000006097 [ncp.at] TRACE: > AT+UBANDMASK?
0000006100 [ncp.at] TRACE: < +UBANDMASK: 0,6170,0
0000006101 [ncp.at] TRACE: < OK
0000006101 [ncp.at] TRACE: > AT+COPS=3,2
0000006104 [ncp.at] TRACE: < OK
0000006104 [ncp.at] TRACE: > AT+CGEREP=1,0
0000006107 [ncp.at] TRACE: < OK
0000006107 [ncp.at] TRACE: > AT+URAT?
0000006110 [ncp.at] TRACE: < +URAT: 7
0000006110 [ncp.at] TRACE: < OK
0000006110 [ncp.at] TRACE: > AT+CPSMS?
0000006113 [ncp.at] TRACE: < +CPSMS: 0,,,"00010011","00000011"
0000006114 [ncp.at] TRACE: < OK
0000006114 [ncp.at] TRACE: > AT+CEDRXS?
0000006117 [ncp.at] TRACE: < +CEDRXS: 4,"0000"
0000006118 [ncp.at] TRACE: < OK
0000006118 [ncp.at] TRACE: > AT+UPSV?
0000006121 [ncp.at] TRACE: < +UPSV: 0
0000006121 [ncp.at] TRACE: < OK
0000006121 [ncp.at] TRACE: > AT+UPSV=1
0000006124 [ncp.at] TRACE: < OK
0000006125 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
0000006130 [ncp.at] TRACE: < OK
0000006130 [mux] INFO: Starting GSM07.10 muxer
0000006131 [mux] INFO: Opening mux channel 0
0000006131 [mux] INFO: GSM07.10 muxer thread started
0000006134 [mux] INFO: Opening mux channel 1
0000006138 [ncp.at] TRACE: > AT
0000006142 [ncp.at] TRACE: < OK
0000006142 [ncp.client] TRACE: NCP state changed: 1
0000006142 [net.pppncp] TRACE: NCP event 1
0000006143 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0000006144 [net.ppp.client] TRACE: State NONE -> READY
0000006147 [ncp.at] TRACE: > AT
0000006149 [ncp.at] TRACE: < OK
0000006150 [ncp.at] TRACE: > AT+CFUN?
0000006153 [ncp.at] TRACE: < +CFUN: 1,7
0000006154 [ncp.at] TRACE: < OK
0000006155 [ncp.at] TRACE: > AT+CCID
0000006182 [ncp.at] TRACE: < +CCID: 89883070000037636055
0000006183 [ncp.at] TRACE: < OK
0000006184 [ncp.at] TRACE: > AT+CGDCONT?
0000006189 [ncp.at] TRACE: < +CGDCONT: 1,"IP","super","0.0.0.0",0,0,0,2,0,0,0,0,0,0,0
0000006190 [ncp.at] TRACE: < OK
0000006191 [ncp.at] TRACE: > AT+CFUN?
0000006195 [ncp.at] TRACE: < +CFUN: 1,7
0000006195 [ncp.at] TRACE: < OK
0000006196 [ncp.at] TRACE: > AT+CEREG=2
0000006199 [ncp.at] TRACE: < OK
0000006200 [ncp.client] TRACE: NCP connection state changed: 1
0000006200 [net.pppncp] TRACE: NCP event 2
0000006200 [net.pppncp] TRACE: State changed event: 1
0000006201 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000006201 [ncp.at] TRACE: > AT+COPS?
0000006205 [ncp.at] TRACE: < +COPS: 0
0000006205 [ncp.at] TRACE: < OK
0000006206 [ncp.at] TRACE: > AT+CEREG?
0000006209 [ncp.at] TRACE: < +CEREG: 2,0
0000006210 [ncp.at] TRACE: < OK
0000007810 [ncp.at] TRACE: < +CEREG: 5,"a9fe","01c24e0c",7
0000007811 [ncp.client] TRACE: NCP connection state changed: 2
0000007812 [mux] INFO: Opening mux channel 2
0000009046 [net.pppncp] TRACE: NCP event 100
0000009047 [net.pppncp] TRACE: New auth info
0000009049 [net.pppncp] TRACE: NCP event 2
0000009049 [net.pppncp] TRACE: State changed event: 2
0000009051 [net.ppp.client] TRACE: PPP thread event LOWER_UP data=0
0000009051 [net.ppp.client] TRACE: State READY -> CONNECT
0000009050 [ncp.at] TRACE: > AT+CIMI
0000009054 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0000009076 [ncp.at] TRACE: < 234104869459302
0000009077 [ncp.at] TRACE: < OK
0000009078 [ncp.at] TRACE: > AT
0000009080 [ncp.at] TRACE: < OK
0000009081 [ncp.at] TRACE: > AT+CGATT?
0000009085 [ncp.at] TRACE: < +CGATT: 1
0000009085 [ncp.at] TRACE: < OK
0000010087 [ncp.at] TRACE: > AT
0000010090 [ncp.at] TRACE: < OK
0000010091 [ncp.at] TRACE: > AT+UPORTFWD=100,1
0000010095 [ncp.at] TRACE: < +UPORTFWD: 100,1
0000010095 [ncp.at] TRACE: < OK
0000010096 [ncp.at] TRACE: > ATD*99***1#
0000010102 [ncp.at] TRACE: < CONNECT
0000010103 [net.ppp.client] TRACE: PPP phase -> Initialize
0000010104 [net.ppp.client] TRACE: PPP phase -> Establish
0000010105 [lwip.ppp] TRACE: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x58521a75> <pcomp> <accomp>]
0000010113 [lwip.ppp] TRACE: rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0x58521a75> <pcomp> <accomp>]
0000013402 [lwip.ppp] TRACE: rcvd [LCP ConfReq id=0x1 <asyncmap 0x0> <mru 1360> <auth pap> <accomp> <pcomp>]
0000013403 [lwip.ppp] TRACE: sent [LCP ConfAck id=0x1 <asyncmap 0x0> <mru 1360> <auth pap> <accomp> <pcomp>]
0000013405 [lwip.ppp] TRACE: sent [LCP EchoReq id=0x0 magic=0x58521a75]
0000013405 [net.ppp.client] TRACE: PPP phase -> Authenticate
0000013406 [lwip.ppp] TRACE: sent [PAP AuthReq id=0x1 user="" password=""]
0000013415 [lwip.ppp] TRACE: rcvd [LCP EchoRep id=0x0 magic=0x0]
0000013418 [lwip.ppp] TRACE: rcvd [PAP AuthAck id=0x1 "Login successful."]
0000013418 [net.ppp.client] TRACE: PPP phase -> Network
0000013420 [lwip.ppp] TRACE: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <msdns1 8.8.8.8> <msdns2 8.8.4.4>]
0000013421 [lwip.ppp] TRACE: rcvd [IPCP ConfReq id=0x0 <addr 192.168.201.2>]
0000013422 [lwip.ppp] TRACE: sent [IPCP ConfNak id=0x0 <addr 192.168.201.2>]
0000013432 [lwip.ppp] TRACE: rcvd [IPCP ConfNak id=0x1 <addr 192.168.201.1> <msdns1 8.8.4.4> <msdns2 8.8.8.8>]
0000013433 [lwip.ppp] TRACE: sent [IPCP ConfReq id=0x2 <addr 192.168.201.1> <msdns1 8.8.4.4> <msdns2 8.8.8.8>]
0000013435 [lwip.ppp] TRACE: rcvd [IPCP ConfReq id=0x1 <addr 192.168.201.2>]
0000013435 [lwip.ppp] TRACE: sent [IPCP ConfAck id=0x1 <addr 192.168.201.2>]
0000013443 [lwip.ppp] TRACE: rcvd [IPCP ConfAck id=0x2 <addr 192.168.201.1> <msdns1 8.8.4.4> <msdns2 8.8.8.8>]
0000013447 [system.nm] INFO: State changed: IFACE_UP -> IFACE_LINK_UP
0000013448 [system.nm] INFO: State changed: IFACE_LINK_UP -> IP_CONFIGURED
0000013449 [net.ppp.client] TRACE: PPP phase -> Running
0000013448 [net.ppp.client] TRACE: PPP thread event UP data=0
0000013450 [net.ppp.client] TRACE: State CONNECTING -> CONNECTED
0000013452 [net.pppncp] TRACE: Negotiated MTU: 1360
0000013453 [system] INFO: Cloud: connecting
0000013454 [system] WARN: Failed to load session data from persistent storage
0000013823 [system] INFO: Cloud socket connected
0000013823 [comm.protocol.handshake] INFO: Establish secure connection
0000013826 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=2
0000017920 [comm.protocol.handshake] INFO: Sending HELLO message
0000017921 [comm.coap] TRACE: Sending CoAP message
0000017921 [comm.coap] TRACE: CON POST /h size=39 token= id=1
0000018035 [comm.coap] TRACE: Received CoAP message
0000018035 [comm.coap] TRACE: ACK 0.00  size=4 token= id=1
0000018036 [comm.protocol.handshake] INFO: Handshake completed
0000018036 [comm.protocol.handshake] TRACE: Updating cached session parameters
0000018036 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000018038 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000018223 [ncp.at] TRACE: > AT+CFUN?
0000018227 [ncp.at] TRACE: < +CFUN: 1,7
0000018227 [ncp.at] TRACE: < OK
0000018228 [ncp.at] TRACE: > AT+CCID
0000018275 [ncp.at] TRACE: < +CCID: 89883070000037636055
0000018275 [ncp.at] TRACE: < OK
0000018276 [ncp.at] TRACE: > AT+CGSN
0000018280 [ncp.at] TRACE: < 351457833663245
0000018281 [ncp.at] TRACE: < OK
0000018281 [ncp.at] TRACE: > ATI9
0000018285 [ncp.at] TRACE: < 03.15,A00.01
0000018285 [ncp.at] TRACE: < OK
0000018287 [comm.coap] TRACE: Sending CoAP message
0000018288 [comm.coap] TRACE: CON POST /d?\x01 size=220 token=d6 id=2
0000018292 [comm.coap] TRACE: Sending CoAP message
0000018292 [comm.coap] TRACE: CON POST /E/spark/device/last_reset size=42 token= id=3
0000018294 [comm.coap] TRACE: Sending CoAP message
0000018294 [comm.coap] TRACE: CON POST /E/particle/device/updates/enabled size=44 token= id=4
0000018296 [comm.coap] TRACE: Sending CoAP message
0000018296 [comm.coap] TRACE: CON POST /E/particle/device/updates/forced size=44 token= id=5
0000018298 [comm.coap] TRACE: Sending CoAP message
0000018298 [comm.coap] TRACE: CON GET /t size=7 token=d7 id=6
0000018458 [comm.coap] TRACE: Received CoAP message
0000018458 [comm.coap] TRACE: ACK 0.00  size=5 token=d6 id=2
0000018459 [comm.protocol] TRACE: Updating system DESCRIBE checksum
0000018459 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000018660 [ncp.at] TRACE: > AT+CFUN?
0000018663 [ncp.at] TRACE: < +CFUN: 1,7
0000018663 [ncp.at] TRACE: < OK
0000018664 [ncp.at] TRACE: > AT+CCID
0000018689 [ncp.at] TRACE: < +CCID: 89883070000037636055
0000018689 [ncp.at] TRACE: < OK
0000018690 [ncp.at] TRACE: > AT+CGSN
0000018693 [ncp.at] TRACE: < 351457833663245
0000018694 [ncp.at] TRACE: < OK
0000018694 [ncp.at] TRACE: > ATI9
0000018698 [ncp.at] TRACE: < 03.15,A00.01
0000018698 [ncp.at] TRACE: < OK
0000018699 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000018700 [comm.coap] TRACE: Received CoAP message
0000018700 [comm.coap] TRACE: ACK 0.00  size=4 token= id=3
0000018701 [comm.coap] TRACE: Received CoAP message
0000018701 [comm.coap] TRACE: ACK 0.00  size=4 token= id=4
0000018702 [comm.coap] TRACE: Received CoAP message
0000018703 [comm.coap] TRACE: ACK 2.05  size=10 token=d7 id=6
0000018703 [comm.protocol] INFO: Received TIME response: 1734649791
0000018704 [comm.coap] TRACE: Received CoAP message
0000018705 [comm.coap] TRACE: ACK 0.00  size=4 token= id=5
0000018706 [system] INFO: Cloud connected
0000018706 [app] INFO: Tinker app setup starting
0000018707 [app] INFO: Tinker app setup complete
0000018707 [comm.coap] TRACE: Sending CoAP message
0000018708 [comm.coap] TRACE: CON POST /d?\x02 size=80 token=d8 id=7
0000018709 [comm.protocol] INFO: Sending subscriptions
0000018710 [comm.coap] TRACE: Sending CoAP message
0000018710 [comm.coap] TRACE: CON GET /e/particle?u size=17 token= id=8
0000018712 [comm.coap] TRACE: Sending CoAP message
0000018712 [comm.coap] TRACE: CON GET /e/spark?u size=14 token= id=9
0000018859 [comm.coap] TRACE: Received CoAP message
0000018859 [comm.coap] TRACE: ACK 0.00  size=5 token=d8 id=7
0000018860 [comm.protocol] TRACE: Updating application DESCRIBE checksum
0000018860 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000018861 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000018871 [comm.coap] TRACE: Received CoAP message
0000018871 [comm.coap] TRACE: ACK 0.00  size=4 token= id=8
0000018882 [comm.coap] TRACE: Received CoAP message
0000018882 [comm.coap] TRACE: ACK 0.00  size=4 token= id=9
0000018883 [comm.protocol] TRACE: Updating subscriptions checksum
0000018883 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000018884 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000019498 [comm.coap] TRACE: Received CoAP message
0000019499 [comm.coap] TRACE: CON POST /E/particle/device/updates/pending size=47 token=01 id=64123
0000019499 [comm.coap] TRACE: Sending CoAP message
0000019500 [comm.coap] TRACE: ACK 0.00  size=4 token= id=64123
0000020082 [comm.coap] TRACE: Received CoAP message
0000020083 [comm.coap] TRACE: CON GET /d?\x04 size=9 token=02 id=64124
0000020083 [comm.protocol] INFO: Received DESCRIBE request; flags: 0x04
0000020084 [comm.coap] TRACE: Sending CoAP message
0000020084 [comm.coap] TRACE: ACK 0.00  size=4 token= id=64124
0000020086 [ncp.at] TRACE: > AT+COPS=3,2
0000020092 [ncp.at] TRACE: < OK
0000020093 [ncp.at] TRACE: > AT+COPS?
0000020096 [ncp.at] TRACE: < +COPS: 0,2,"310260",7
0000020097 [ncp.at] TRACE: < OK
0000020098 [ncp.at] TRACE: > AT+UCGED?
0000020584 [ncp.at] TRACE: < +UCGED: 2
0000020585 [ncp.at] TRACE: < 6,4,310,260
0000020585 [ncp.at] TRACE: < 676,2,25,25,a9fe,1c24e0c,67,d2eec14b,8003,21,23,19,2.31,3,255,255,22,23,23,0,255,255,80
0000020587 [ncp.at] TRACE: < OK
0000020588 [ncp.at] TRACE: > AT+COPS=3,2
0000020592 [ncp.at] TRACE: < OK
0000020592 [ncp.at] TRACE: > AT+COPS?
0000020596 [ncp.at] TRACE: < +COPS: 0,2,"310260",7
0000020597 [ncp.at] TRACE: < OK
0000020598 [ncp.at] TRACE: > AT+CEREG?
0000020601 [ncp.at] TRACE: < +CEREG: 2,5,"a9fe","01c24e0c",7
This is the full program that is running:
#include "Particle.h"
// Serial logger for debugging via TX/RX pins
SerialLogHandler logHandler(LOG_LEVEL_ALL);
int tinkerDigitalWrite(String command);
int tinkerDigitalRead(String command);
int tinkerAnalogWrite(String command);
int tinkerAnalogRead(String command);
    // Initialize Serial1 for TX/RX debugging
    Log.info("Tinker app setup starting");
    // Register Particle functions for Tinker app
    Particle.function("digitalWrite", tinkerDigitalWrite);
    Particle.function("digitalRead", tinkerDigitalRead);
    Particle.function("analogWrite", tinkerAnalogWrite);
    Particle.function("analogRead", tinkerAnalogRead);
    Log.info("Tinker app setup complete");
    // Log something periodically for debugging
    // Log.info("Tinker app running");
    // delay(1); // Adjust as needed for debugging
// Tinker app functions
int tinkerDigitalWrite(String command) {
    Log.info("digitalWrite command received: %s", command.c_str());
    bool value = 0;
    int pin = command.charAt(1) - '0';
    String valueStr = command.substring(3);
    if (valueStr == "HIGH") value = 1;
    else if (valueStr == "LOW") value = 0;
    else return -2; // Error: Invalid value
    if (command.startsWith("D") && (pin >= 0 && pin <= 7)) {
        pinMode(pin, OUTPUT);
        digitalWrite(pin, value);
        return 1;
    } else {
        return -1; // Error: Invalid pin
int tinkerDigitalRead(String command) {
    Log.info("digitalRead command received: %s", command.c_str());
        pinMode(pin, INPUT_PULLDOWN);
        return digitalRead(pin);
    } else {
int tinkerAnalogWrite(String command) {
    Log.info("analogWrite command received: %s", command.c_str());
    int value = command.substring(3).toInt();
        analogWrite(pin, value);
        return 1;
    } else {
int tinkerAnalogRead(String command) {
    Log.info("analogRead command received: %s", command.c_str());
    if (command.startsWith("A") && (pin >= 0 && pin <= 5)) {
        pinMode(pin, INPUT);
        return analogRead(pin);
    } else {
Following, nice work on the diagnostics. We might have several cases of the same bug out in the wild, I’ll see what readings I can share after Xmas, but the consumption numbers sounds similar to what we saw on the B524 that we had retrieved
Thanks for confirming @claursen. Would be great to share any additional information you might have such as Device OS versions and when did you first observe it? My biggest concern is I’m not able to simply downgrade device OS back to 5.5.0 and fix the issue. My use case is seasonal and so we didn’t have battery operated devices in the field the last 6 months so I don’t have any tangible evidence on when the issue was first observed.
It’s either something on the cloud/cellular side that has changed and the entire battery operated fleet will be impacted or it’s possible it’s the latest batch of BRN404X hardware I’m testing now. I think I have several earlier batches of BRN404xs some BRN404 as well as some BRN402s. I was going to try and do some testing with them to see what devices in the fleet will be impacted but I’m out of town until the 26th. I hope to resume some additional testing then.
@ericpietrowicz, @no1089,
First off... Happy New Year! - I recognize Particle might still be on skeleton crew this week with the New Years, but can you please share an update regarding this issue? Has the engineering team identified a potential cause? Is there anything I can do to help accelerate the learnings and get too root cause? Happy to run tests and report back. Just let me know how I can help.
I now have a proper hardware to measure power consumptions with a Power Profile Kit II. WAY better then that Current Ranger I had before. I opened it up so I can re-produce some of my tests/observations in a more precise manner.
Notice here, the device was running along fine at 9 mA with an occasional spike, but then goes erratic at an average of 80 mA.
As soon as I call a particle function it stabilizes back to 9 mA again. The arrow is when I called a digitalRead(). It'll then stabilize for maybe 30 seconds, maybe 1 minute maybe even 10 minutes but it will normally jump back up.
Are you able to re-produce this behavior on your side as well? Would certainly appreciate an update!
Hi @jgskarda I have not heard much of an update from engineering over the holidays regarding this issue, but I can confirm that we are able to reproduce it.
I will keep you updated once I hear something. Thank you for the detailed reporting you have been doing.
