Could you help, what is wrong with this code?
It sometimes works fine, sometimes is stucking in breathing white
Why?
#include "application.h"
#define OLED_Address 0x3c
#define OLED_Command_Mode 0x80
#define OLED_Data_Mode 0x40
Wire.begin();
void sendData(unsigned char data)
Wire.beginTransmission(OLED_Address); // **** Start I2C
Wire.write(OLED_Data_Mode); // **** Set OLED Data mode
Wire.write(data);
Wire.endTransmission(); // **** End I2C
void sendCommand(unsigned char command)
Wire.write(OLED_Command_Mode); // **** Set OLED Command mode
Wire.write(command);
delay(10);
void send_string(const char *String)
unsigned char i=0;
while(String[i])
sendData(String[i]); // *** Show String to OLED
i++;
bool lcdActive = false;
void initLCD() {
// *** I2C initial *** //
delay(100);
sendCommand(0x2A); // **** Set "RE"=1 00101010B
sendCommand(0x71);
sendCommand(0x5C);
sendCommand(0x28);
sendCommand(0x08); // **** Set Sleep Mode On
sendCommand(0x79); // **** Set "SD"=1 01111001B
sendCommand(0xD5);
sendCommand(0x70);
sendCommand(0x78); // **** Set "SD"=0
sendCommand(0x08); // **** Set 5-dot, 3 or 4 line(0x09), 1 or 2 line(0x08)
sendCommand(0x06); // **** Set Com31-->Com0 Seg0-->Seg99
// **** Set OLED Characterization *** //
// **** CGROM/CGRAM Management *** //
sendCommand(0x72); // **** Set ROM
sendCommand(0x00); // **** Set ROM A and 8 CGRAM
sendCommand(0xDA); // **** Set Seg Pins HW Config
sendCommand(0x10);
sendCommand(0x81); // **** Set Contrast
sendCommand(0xFF);
sendCommand(0xDB); // **** Set VCOM deselect level
sendCommand(0x30); // **** VCC x 0.83
sendCommand(0xDC); // **** Set gpio - turn EN for 15V generator on.
sendCommand(0x03);
sendCommand(0x78); // **** Exiting Set OLED Characterization
sendCommand(0x28);
sendCommand(0x2A);
//sendCommand(0x05); // **** Set Entry Mode
sendCommand(0x06); // **** Set Entry Mode
sendCommand(0x08);
sendCommand(0x28); // **** Set "IS"=0 , "RE" =0 //28
sendCommand(0x01);
sendCommand(0x80); // **** Set DDRAM Address to 0x80 (line 1 start)
delay(100);
sendCommand(0x0C); // **** Turn on Display
if(!lcdActive) {
initLCD();
lcdActive = true;
// **** Show Data Value *** //
send_string("0123456789ABCDEF");
sendCommand(0xC0); // **** New Line
send_string("Русский?");
//sendCommand(0x01); // **** Clear display
