Hello
I am desolate, a few days ago I performed the setups of my new Boron 2g/3g with internal sim card and everything worked fine, today I wanted to update my boron with the particle update command unfortunately from the console I received an error like below and it ist flashing yellow fast:
C:\Users\valentino>particle update
> Your device is ready for a system update.
> This process should take about 30 seconds. Here it goes!
! An error occurred while attempting to update the system firmware of your device:
Error: VError: Error writing firmware: Invalid DFU suffix signature
Error during special command "ERASE_PAGE" get_status
> Please visit our community forums for help with this error:
https://community.particle.io/
Cannot read property 'code' of undefined
I state that I have carried out the suggestions given to me by ScruffR in my other place with a similar error but with negative results.
You may want to create a support ticket as the error “Error during special command “ERASE_PAGE” get_status” may indicate a hardware failure (the operation failed when erasing the flash memory).
Hello
thanks @rickkas7 and @ScruffR for your answers this evening I will open a ticket to the technical support as recommended.
Greetings from Switzerland
Valentino
Hello @ScruffR and @rickkas7
after opening a ticket I received a reply msg where they asked to execute the command particle update -v again.
This solved the problem I am attaching below what was written in response to technical support.
Boron is now alive. I used the particle update -v command and this was successful. After the message ‘Your device should now restart automatically.’ it stayed in listening mode flashing blue I ran the particle usb setup-done command and went into safe mode to get out of this situation I ran the particle flash --usb tinker command. Now everything is in order but I would like to understand where I went wrong at the beginning.
Thanks also to you for your availability in the community.
Valentino
