Boron: Is daily System.reset() good hygiene?
Quick question for Borons that are always connected to the Particle Cloud and always running their "loop" with the following enabled:
SYSTEM_THREAD(ENABLED);
SYSTEM_MODE(AUTOMATIC);
Would a built-in daily System.reset() be good overall hygiene?
@sensorcheck ,
This is a great question.
I have devices that are set up like this and have run for years without a regular system reset.
My preference is only to reset for a reason as resetting can bring its own issues. I look for things like: running low on memory, persistent connectivity issues, sensor malfunctions and then decide if a reset might fix the issue.
Interested to learn about what others think.
Chip
I started resetting the system monthly, years ago before joining this forum. My reasoning for this was that I was not sure I was coding well enough to deal with millis() and allow it to rollover properly, among other things.
@rickkas7 posted a tutorial about properly coding to handle rollover: https://community.particle.io/t/millis-and-rollover-tutorial/20429
I adopted the techniques he and others talked about on the subject (thanks for that!). But, you know, I still kept performing the monthly reset in firmware, for the most part.
Another thing I do is enable an outOfMemoryHandler() and reset when an error flag occurs. Here is a posting which was valuable reading to me: https://community.particle.io/t/ram-space-running-out/63756
Thank you to all for the contributions!
I do have my devices reset once a week, just in case I have a memory leak. Since the cellular connection stays active during a System.reset(), reconnection normally just takes a few seconds, which is fine in my application.
oh, that's a very cool detail to know. Thanks
I also do the same, but I was embarrassed to admit it again publically.
I'm not embarrassed at all now......somewhat proud :grinning:
Does device reset also cause device console statistics to be reset? I think yes, which is a good thing for understanding how much elapsed time such statistics as cloud disconnects represents.
For all of the reasons given I'm testing a daily reset. Since thanks to all contributors!
