Boron cell connection light
hi i have a box for the boron so i cant see if its connected to cell service
is there a way to code an io pin to go high and hook it to a led outside of box to be on when boron connects?
thanks
You could either mirror the RGB LED to an external one: mirrorTo() - RGB | Reference | Particle
Or you could poll for Particle.connected() and toggle an LED.
Hi @cal39
This works really well, I use it often.
Regards
Friedl
I ordered a rgb led and will try code soon
