Running a very simple program on Particle Photon - below.
Using an Analog input A0 to display a gauge on Blynk, the code runs great about 1/2 hour, then for no reason I can find the Analog input on the Particle goes low impedance (like a it was switched to a Digital output and sent low). This is verified with a DMM. So the analog readings are very low after this event. A reset of the Particle board usually fixes this for a few minutes, not always. Other programs on the Particle without Blynk work fine - Tinker for example
Using Blynk library 0.3.8, Particle Photon using 0.5.2
#include "blynk/blynk.h"
char auth[] = "771825b75e0c4177874595*******";
delay(5000);
Blynk.begin(auth);
Blynk.run();
Reply
