Photon flashing blue after a few minutes
I have been following a blnyk tutorial using the adafruit htd210 however after a few minutes my photon flashes blue then my only way out is to set the WiFi credentials again.
here is the code i have…any advice would be great
Thanks…Ben
#include "blynk/blynk.h"
#include "HTU21D/HTU21D.h"
//#include "HTU21D/HTU21D.h"
HTU21D htu = HTU21D();
double tempVal, tempFVal, humidVal;
char auth[] = "*****************************";
    //Serial.begin(9600);
    Blynk.begin(auth);
    if (!htu.begin()){
        Serial.println("Couldn't find sensor!");
        while(1) Particle.process();
BLYNK_READ(V0){
    Blynk.virtualWrite(V0, round(tempVal*100)/100);
BLYNK_READ(V1){
    Blynk.virtualWrite(V1, round(tempFVal*100)/100);
 BLYNK_READ(V2){
    Blynk.virtualWrite(V2, humidVal);
    Blynk.run();
    //Serial.print("Temp: "); Serial.print(htu.readTemperature()); Serial.print(" C"); Serial.print("\t"); Serial.print(tempFVal); Serial.print(" F");
    //Serial.print("\t\tHUM: "); Serial.print(htu.readHumidity()); Serial.println(" %");
    //Serial.println("");
   delay(10000);
    tempVal = htu.readTemperature();
    tempFVal = ((9.0/5.0)*tempVal + 32);
    humidVal = htu.readHumidity();
You should not have a delay(10000) block Blynk.run() that long.
Rather go with a non-blocking approach
uint32_t msSoftDelay;
    Blynk.run();
    if (millis() - msSoftDelay >= 10000)
        msSoftDelay = millis();
BTW, have you tried Safe Mode when you got into these troubles?
yes i tried safe mode however this did not work
the 10 second timer was not in there until after the fault was occurring as i thought i may have been sending the max data allowed
