BLE Write Characteristic Not Working, Peer Device Missing Error
Hi All,
I am trying to make a particle app that can communicate with a Flutter app. I am using both my own built flutter app and the NRF app while developing the particle code. When I try to write a value to my SCharacteristic it seems like my onDataReceived app is not being called. However I do get the following error from the particle serial monitor:
0001066308 [wiring.ble] ERROR: Peer device is missing!
Hoping I have done something stupid and just left something out. Any troubleshooting help would be greatly appreciated.
#include "Particle.h"
SYSTEM_THREAD(ENABLED);
SerialLogHandler logHandler(LOG_LEVEL_INFO);
const unsigned long UPDATE_INTERVAL_MS = 2000;
unsigned long lastUpdate = 0;
const BleUuid serviceUuid("5c1b9a0d-b5be-4a40-8f7a-66b36d0a5176");
BleCharacteristic WeightCharacteristic("Weight", BleCharacteristicProperty::NOTIFY, BleUuid("b8dfe276-54d4-4e5b-8daa-252157d0e1a9"), serviceUuid);
BleCharacteristic SCharacteristic("S", BleCharacteristicProperty::WRITE_WO_RSP, BleUuid("0554102a-5399-4f1c-9e56-6a071dddd4b8"), serviceUuid, onDataReceived, NULL);
float lastValue = 37.0;
	(void)logHandler; // Does nothing, just to eliminate the unused variable warning
	BLE.on();
	Serial.begin();
    String id = System.deviceID();
	BLE.addCharacteristic(WeightCharacteristic);
	BLE.addCharacteristic(SCharacteristic);
    SCharacteristic.onDataReceived(onDataReceived, NULL);
	BleAdvertisingData advData;
	advData.appendLocalName(id.c_str());
	advData.appendServiceUUID(serviceUuid);
	BLE.advertise(&advData);
	Serial.println("setup complete");
void update_ble_characteristic(BleCharacteristic c, float v){
    int32_t newValue = int32_t(v*1000);
    c.setValue(newValue);
	if (millis() - lastUpdate >= UPDATE_INTERVAL_MS){
		lastUpdate = millis();
		if (BLE.connected()){
			float value = lastValue;
			update_ble_characteristic(WeightCharacteristic, value);
			for(int i=0;i<10;i++){
			    delay(5);
			    value += 0.1;
void onDataReceived(const uint8_t* data, size_t len, const BlePeerDevice& peer, void* context) {
    Serial.println("Data Incoming");
    for (size_t ii = 0; ii < len; ii++) {
        Serial.write(data[ii]);
I fear the device ID plus the service UUID will not fit in your advertising data (unless you use BLE_PHYS_CODED which is not supported by many devices yet).
With a 16 byte UUID in the advertising data your local name should not be longer than 8 characters.
With a slightly altered code which uses a shorter name I get the data just fine.
Testing your peripheral with an app like nRF Connect often helps debugging.
With the long name the device was not discoverable for the app.
SerialLogHandler logHandler(LOG_LEVEL_ERROR, {{"app", LOG_LEVEL_INFO}});
const BleUuid srvUuid("5c1b9a0d-b5be-4a40-8f7a-66b36d0a5176");
const BleUuid txUuid("b8dfe276-54d4-4e5b-8daa-252157d0e1a9");
const BleUuid rxUuid("0554102a-5399-4f1c-9e56-6a071dddd4b8");
BleCharacteristic WeightCharacteristic("Weight", BleCharacteristicProperty::NOTIFY, txUuid, srvUuid);
BleCharacteristic SCharacteristic("S", BleCharacteristicProperty::WRITE_WO_RSP, rxUuid, srvUuid, onDataReceived, NULL);
  BLE.on();
  advData.appendLocalName("12345678");
  advData.appendServiceUUID(srvUuid);
  Log.info("setup complete");
void update_ble_characteristic(BleCharacteristic c, float v) {
  static uint32_t ms = 0;
  if(millis() - ms < UPDATE_INTERVAL_MS) return;
  ms = millis();
    update_ble_characteristic(WeightCharacteristic, random(100) / 10.0);
  Log.info("Data Incoming");
  Serial.println();
Interesting point, I do see that my device name is being truncated. However I am still able to detect and read the notifying characteristic. The only problem is the write characteristic. Are you also able to write to the write characteristic?
I will shorten my device name and test on NRF again.
Yes, this is what I meant when I said
I meant I'm getting the data in my serial monitor connected to my Argon.
But in my code I mixed up the names for rx and tx
corrected :blush:
So I have tried this code and still can't get the write characteristic to work. I still get the
when I try to write a value to the WRITE characteristic. Seems unlikely this could be a device issue, but will quickly test with a different boron.
Ok so it does seem to be specific to one device. Your sketch works perfectly on one but on the other I get the peer error. Weird!
What device OS version is the stubborn device running?
Can you try building agains 3.2.0-rc.1 and try with that?
Good question, overlooked firmware version because I am using web IDE, normally don’t have to worry when I use workbench.
Boron #1 - v1.4.2 - working
Boron #2 - v3.1.0 - not working
After update to v3.2.0-rc.1
Boron #1 - working
Boron #2 - working
Thanks a million, seems like v3.1.0 was the issue.
I guess the current default 2.2.0 should also have worked.
