Could someone from Particle please confirm how the additional request to the peripheral should be performed to get the scanResponse data?
The following fields are provided:
// DEFINITION
class BleScanResult {
public:
BleAddress address;
BleAdvertisingData advertisingData;
BleAdvertisingData scanResponse;
int8_t rssi;
addressThe BLE address of the peripheral. You use this if you want to connect to it. SeeBleAddress. -
advertisingDataThe advertising data provided by the peripheral. It’s small (up to 31 bytes). -
scanResponseThe scan response data. This is an optional extra 31 bytes of data that can be provided by the peripheral. It requires an additional request to the peripheral, but is less overhead than connecting. -
rssiThe signal strength, which is a negative number of dBm. Numbers closer to 0 are a stronger signal.
