BLE fails to connect to peripheral as central after connecting as a peripheral to iPhone
This issue described below occurs on 5.9 and 6.2 on the photon 2
My scenario is that I have a medical device that is a UART peripheral and the P2 must detect and take is data and pass it on to the phone via BLE. The phone is a central and the P2 is a peripheral to the phone, and obviously a central to the medical device.
medical device --> P2 --> iPhone
If I connect to the medical device first, the p2 can then connect to the iPhone successfully after advertising without issue. However, the reverse does not work. If I connect to the iPhone first, then when scanning for the medical device, it detects it, but it fails to connect to it.
I have tried to reduce the code to a minimal set and make it easy to test the 2 scenarios with a couple of booleans.
#include "Particle.h"
SYSTEM_MODE(MANUAL);
SYSTEM_THREAD(ENABLED);
// Case #1 - connect to medical device first then iPhone
volatile bool shouldBeScanning = true;
volatile bool shouldAdvertiseToIphone = false;
// Case #2 - connect to iPhone first then medical device
// volatile bool shouldBeScanning = false;
// volatile bool shouldAdvertiseToIphone = true;
SerialLogHandler logHandler(LOG_LEVEL_ALL, {
                                               // Logging level for non-application messages
                                               {"app", LOG_LEVEL_ALL} // Logging level for application messages
const char *BLT_DEVICE_NAME = "BLT_dev01";
const char *BLT_SERVICE_UUID = "9f6e6f56-aaaa-bbbb-b213-ab2d0dc4ae37";
const char *BLT_TIME_UUID = "9f6e6f56-aaaa-bbbb-b214-ab2d0dc4ae37";
void onTimeDataReceived(const uint8_t *data, size_t len, const BlePeerDevice &peer, void *context);
const char *IMPLANT_SERVICE_UUID = "6E400001-B5A3-F393-E0A9-E50E24DCCA9E";
const char *IMPLANT_TX_UUID = "6E400002-B5A3-F393-E0A9-E50E24DCCA9E";
const char *IMPLANT_RX_UUID = "6E400003-B5A3-F393-E0A9-E50E24DCCA9E";
BleCharacteristic implantTXCharacteristic("implant_tx", BleCharacteristicProperty::NOTIFY, IMPLANT_TX_UUID, IMPLANT_SERVICE_UUID);
BleCharacteristic implantRXCharacteristic("implant_rx", BleCharacteristicProperty::WRITE_WO_RSP, IMPLANT_RX_UUID, IMPLANT_SERVICE_UUID);
BleCharacteristic timeCharacteristic("time", BleCharacteristicProperty::WRITE, BLT_TIME_UUID, BLT_SERVICE_UUID, onTimeDataReceived);
BlePeerDevice iPhoneCentralDevice;
BleAdvertisingData advData;
volatile bool shouldDisconnect = false;
BleScanResult scanResults[20];
BleScanFilter filter = BleScanFilter();
BlePeerDevice implantDevice;
const unsigned long SCAN_PERIOD_MS = 2000;
unsigned long lastScan = 0;
void onConnectedToPhone(const BlePeerDevice &peer, void *context)
  iPhoneCentralDevice = peer;
  Serial.println("Connected to phone with address " + iPhoneCentralDevice.address().toString());
void dataReceivedCallback(const uint8_t *data, size_t len, const BlePeerDevice &peer, void *context)
  Serial.print(".");
  while (!Serial.isConnected())
  BLE.on();
  BLE.onConnected(onConnectedToPhone, NULL);
  BLE.addCharacteristic(timeCharacteristic);
  timeCharacteristic.onDataReceived(onTimeDataReceived, &timeCharacteristic);
  advData.appendServiceUUID(BLT_SERVICE_UUID);
  advData.deviceName((char *)BLT_DEVICE_NAME, strlen(BLT_DEVICE_NAME));
  BLE.setDeviceName(BLT_DEVICE_NAME);
  filter.serviceUUID(IMPLANT_SERVICE_UUID);
  BLE.advertise(&advData);
  implantRXCharacteristic.onDataReceived(dataReceivedCallback, &implantRXCharacteristic);
  if (shouldAdvertiseToIphone)
    if (!iPhoneCentralDevice.connected()) {
    Serial.println("advertising...");
  else
    if (BLE.advertising())
      BLE.stopAdvertising();
  if (!implantDevice.connected())
    if (millis() - lastScan >= SCAN_PERIOD_MS && shouldBeScanning)
      // Time to scan
      lastScan = millis();
      Serial.println("scanning for medical device...");
      auto results = BLE.scanWithFilter(filter);
      if (results.size() > 0)
        auto result = results.first();
        Serial.println("found medical device, attempting to connect to " + result.address().toString() + " ...");
        implantDevice = BLE.connect(result.address());
        if (implantDevice.connected())
          Serial.println("successfully connected to medical device!");
          implantDevice.getCharacteristicByUUID(implantTXCharacteristic, IMPLANT_TX_UUID);
          implantDevice.getCharacteristicByUUID(implantRXCharacteristic, IMPLANT_RX_UUID);
  // if (shouldDisconnect)
  //   shouldDisconnect = false;
  //   Serial.println("Disconnecting...");
  //   if (BLE.advertising())
  //     Serial.println("still advertising....");
  //   else
  //     Serial.println("not advertising!");
  //   iPhoneCentralDevice.disconnect();
  //   BLE.stopAdvertising();
  Serial.println("got time");
Running this code here is my output
l.ble] TRACE: Going to stop the stack...
0000002149 [hal] INFO: WiFi off
0000002158 [system.nm] INFO: State changed: NONE -> DISABLED
0000002174 [system.nm] TRACE: Interface 4 power state: DOWN
0000002212 [comm] INFO: channel inited
0000002233 [hal] INFO: rltk_wlan_set_netif_info: 0, 94:94:4a:04:08:38
0000002380 [hal] INFO: WiFi on
found medical device, attempting to connect to 94:94:4A:04:C1:35 ...
0000007793 [wiring.ble] TRACE: Connected
0000007863 [wiring.ble] TRACE: New peripheral is connected.
0000007879 [wiring.ble] TRACE: Start discovering services.
0000008043 [wiring.ble] TRACE: Start discovering characteristics of service: 1801.
0000008312 [wiring.ble] TRACE: Characteristic discovered.
0000008314 [wiring.ble] TRACE: Start discovering characteristics of service: 1800.
0000008492 [wiring.ble] TRACE: Characteristic discovered.
0000008495 [wiring.ble] TRACE: Start discovering characteristics of service: 6FA90001-5C4E-48A8-94F4-8030546F36FC.
0000009122 [wiring.ble] TRACE: Characteristic discovered.
0000009125 [wiring.ble] TRACE: Start discovering characteristics of service: 6E400001-B5A3-F393-E0A9-E50E24DCCA9E.
0000009842 [wiring.ble] TRACE: Characteristic discovered.
advertising...
advertising...
..advertising...
advertising...
advertising...
a..dvertising...
advertising...
advertising...
advertisi..ng...
advertising...
advertising...
advertising...
..advertising...
advertising...
advertising...
...advertising...
advertising...
advertising...
...Connected to phone with address 53:74:48:69:0D:C9
0000010570 [wiring.ble] TRACE: Connected
..0000010612 [system.ctrl.ble] TRACE: Connected
..........................................got time
One can see that the "Connected to phone" occurs as well as "got time". Additionally as the medical device is sending data I am just printing '.'
Now I will reverse the booleans to have it connect to the iPhone first.
// volatile bool shouldBeScanning = true;
// volatile bool shouldAdvertiseToIphone = false;
Here is the output. As you can see once connected to the iPhone the attempt to connect to the medical device after a successful scan never succeeds.
02061 [hal.ble] TRACE: Going to stop the stack...
0000002389 [hal] INFO: WiFi off
0000002398 [system.nm] INFO: State changed: NONE -> DISABLED
0000002414 [system.nm] TRACE: Interface 4 power state: DOWN
0000002452 [comm] INFO: channel inited
0000002474 [hal] INFO: rltk_wlan_set_netif_info: 0, 94:94:4a:04:08:38
0000002621 [hal] INFO: WiFi on
advertising...
advertising...
advertising...
advertising...
advertising...
advertising...
advertising...
advertising...
advertisConnected to phone with address 53:74:48:69:0D:C9
0000003299 [wiring.ble] TRACE: Connected
ing...
0000003353 [system.ctrl.ble] TRACE: Connected
got time
Any ideas as to why or if I am doing something wrong?
@rickkas7 can I get support to look at this?
Hi @iitgrad, this PR should fix the issue: [Gen4] ble: clear connecting flag on connected for peripheral role by XuGuohui · Pull Request #2839 · particle-iot/device-os · GitHub
Thank you @ielec. Hooray!
