Beta dashboard, cant get to compile when using the below [SOLVED]
PRODUCT_ID(XXX);
PRODUCT_VERSION(0);
setup()
loop()
When I try adding the ID and version. I get compile errors. Im working on the P1 with version 0.4.4.
Any thoughts what I’m doing wrong?
Try to be less “simplistical:wink:
PRODUCT_ID(123);
PRODUCT_VERSION(0);
void setup() { }
void loop() { }
This should compile just fine
BTW: Quoting your compiler errors might be good too. It helps others to spot the error, but it also might give you a hint to solve the riddle yourself :wink:
@ScruffR, I realized you didnt have much to look at.
Below are the compiles error when compiled from the Web IDE for a P1.
<command-line>:0:12: error: expected unqualified-id before numeric constant
v3.0_active.cpp:3:1: note: in expansion of macro 'PRODUCT_ID'
 PRODUCT_ID(139);
			v3.0_active.cpp:4:16: error: expected constructor, destructor, or type conversion before '(' token
 PRODUCT_VERSION(0);
1st few lines of code:
Since I have no P1 to build against and seem to have no problem building against my Photons, could you try to build against a Photon and see if you still get the same error(s)?
Maybe a few more lines of your code (especially setup() and loop()) would be good too.
Alternatively could you whip up some minimal sketch that produces this error and post it in its entirety?
Try to put all your #include directives before the PRODUCT_* makros.
This fails
PRODUCT_ID(123);
PRODUCT_VERSION(0);
#include "application.h"
void setup() { }
void loop() { }
while this builds
PRODUCT_ID(123);
PRODUCT_VERSION(0);
void setup() { }
void loop() { }
Well, that was easy! Didn’t even think to try that.
Thanks working now.
