I have my photon connected to a servo and it is battery powered through micro USB via a small power stick I had laying around (the ones intended to recharge your phones on the go). The problem is, the battery burns out very quickly – within about 12 hrs. I’d like to make this last orders of magnitude longer and I’m guessing it is the wifi module that is pulling all the power.
Is there a mode that can “wake on wifi”, so to speak? Or am I stuck with having to sleep the module and wake every 10 seconds or so and poll a database to see if a command was sent? Or is there another way I’m not thinking of? The servo only needs to rotate once on command and maybe 2 or 3 times a day, the rest of the time, the entire setup needs to do nothing.
Thanks for any pointers.
