Bad output from servo library
I've created a simple code to drive a RC electronic speed control (ESC). If I use the code below, I get an output that varies from 0.5ms to 2.5ms. If I comment out the servo.write() and uncomment the servo.writeMicroseconds(), I get the correct span of 1ms to 2ms. Is there something wrong with my code or is there a bug in servo.write()?
Running on Photon 2 with O/S v5.9.0.
Servo myservo;  // create servo object to control a R/C servo
                // a maximum of eight servo objects can be created
const int PWM_OUTP  = D1;	// 1ms << out_pulse << 2ms
const int SPD_POT = A0;
STARTUP(WiFi.selectAntenna(ANT_INTERNAL));
// Let Device OS manage the connection to the Particle Cloud
SYSTEM_MODE(AUTOMATIC);
// Show system, cloud connectivity, and application logs over USB
// View logs with CLI using 'particle serial monitor --follow'
SerialLogHandler logHandler(LOG_LEVEL_INFO);
    (void)logHandler; // Does nothing, just to eliminate the unused variable warning
    // Configure I/O pins
    pinMode(RUN, INPUT_PULLUP);     // sets pin as input
    pinMode(USER_OUTP, OUTPUT);
    myservo.attach(PWM_OUTP);       // attaches the servo on the D0 pin to the servo object
                                    // Only supported on pins that have PWM
    // Gen 4 devices including the M-SoM, P2, and Photon 2
    analogWrite(PWM_OUTP, 255, 50);
    Log.info("Starting RC Servo... ");
    static int old_pwm  = -1;       // servo position from previous reading
    static int loop_cnt = 0;
    if ( digitalRead(RUN) == LOW )
            int pot = analogRead(SPD_POT);      // read user input; rtns 0-4095
            int pwm = map(pot, 0, 4095, 0, 180);// convert to 0-180 degree
            if (pwm != old_pwm)
                Log.info("Pot is %d/4095, pwm=%d ", pot, pwm);
                old_pwm = pwm;
            myservo.write(pwm);
            //myservo.writeMicroseconds(map(pot, 0, 4095, 1000, 2000));
        delay(100);
    else
        myservo.write(0);
        //myservo.writeMicroseconds(1000);
        delay(1000);
    loop_cnt += 1;
    digitalWriteFast(USER_OUTP, !pinReadFast(USER_OUTP));   // toggle LED
The values in the docs for writeMicroseconds don't match the Device OS code.
#define SERVO_DEFAULT_MIN_PW            544
#define SERVO_DEFAULT_MAX_PW            2400
#define SERVO_DEFAULT_MIN_ANGLE         0
#define SERVO_DEFAULT_MAX_ANGLE         180
The minimum is 544 and the maximum is 2400. Internally, write() calls writeMicroseconds, but it uses those values to map the range.
Thanks @rickkas7, that explains what I'm seeing. But that doesn't match the R/C "standard" afaik, and my ESC throws a "bad input signal" error. Is there some logic to the #defines, or is 544-2400 a newer standard?
The range of 544 - 2400 matches Arduino and it's been that way since the Spark Core, 12 years ago, Device OS 0.4.2. It would seem to be out of spec, but there's a comment not to change it in the code.
Anyway, the advantage of using writeMicroseconds is that you can easily change the mapping to fit your hardware.
Thanks again for taking time to explain it! I agree that writeMicroseconds keeps it explicit and simple.
