Azure integration getaddrinfo ENOTFOUND
I have followed the tutorial here:
When i update the firmware with
// Get some data
  String data = String(10);
  // Trigger the integration
  Particle.publish("JB_Test", data, PRIVATE);
  // Wait 60 seconds
  Serial.println("Sent Test Data");
  delay(60000);
The code flashes fine and i can see it running, then i check the integration log and i can see i am getting the below error:
getaddrinfo ENOTFOUND myhubname.azure-devices.net
I can’t find any information on how to resolve this anywhere online. Any ideas?
Have you made sure the azure endpoint is actually reachable at that domain like outlined here?
https://docs.particle.io/tutorials/integrations/azure-iot-hub/#confirming-the-data-reaches-azure-iot-hub
That error indicates that the domain is not reachable.
Just tried running the command and found that i needed to add -d before the particle device id, but it seemed to run but gave me a long error, the summary is below:
[0] create a generic issue.
[1] az iot hub : FAILURE. Ran: 11 mins ago.
[2] az iot hub monitor-events: FAILURE. Ran: 10 mins ago.
[3] az extension add : SUCCESS. Ran: 9 mins ago.
[4] az iot hub monitor-events: FAILURE. Ran: 9 mins ago.
[5] az iot hub monitor-events: FAILURE. Ran: 8 mins ago.
[6] az iot hub monitor-events: FAILURE. Ran: 8 mins ago.
[7] az iot hub monitor-events: FAILURE. Ran: 4 mins ago.
[8] az iot hub monitor-events: FAILURE. Ran: 1 mins ago.
CLIInternalError: The command failed with an unexpected error. Here is the traceback:
ErrorCodes.UnknownError: Connection in an unexpected error state.
I’ve also just tried running:
az iot hub monitor-events -n {iothub_name}
Using the hub name and it gives me
Unable to find IoT Hub: MY-HUB-NAME in current subscription MYSUBSCRIPTIONNO.
After a lot of digging i’ve discovered that the IoT hub i created through the dashboard was not showing when i ran
az iot hub list -o table
I then used the CLI to create a new hub and this worked first time. Microsoft support were unable to tell me why the dashboard created iot hub wouldn’t show up.
