Hi
I’m unable to get the attachInterrupt function to call the interrupt function
Using 0.5.1-pi.14
I’ve tried GPIO4/GPIO17 with FALLING/RISING/CHANGE - no activity seen
Are there some pins that do work?
Regards
Julian
Hi
Using 0.5.1-pi.14
Regards
Julian
Hi there. Currently interrupts are not supported for the RPi on our platform. It may be something we work in in a future update but I can’t confirm that this would take place any time soon. I apologize for any inconvenience.
Hi
I’ve worked around this problem by calling the WiringPi functions directly as follows
extern "C" int wiringPiISR (int pin, int edgeType, void (* function) (void));
#define INT_EDGE_FALLING 1
#define INT_EDGE_RISING 2
#define INT_EDGE_BOTH 3
wiringPiISR (GPIO4, INT_EDGE_FALLING, isrFunction);
Regards
Julian
Hi
It turns out that the wiringPi package must be installed for this to work
sudo apt-get install wiringpi
Regards
Julian
