attachInterrupt photon panic and restart
Hi All,
I am working on a garage door opener with a sparkfun capacitive touchpad as a button. I am trying to use an interrupt to call the opendoor/closedoor function if the button was touched. Every time I touch the button the photon panics and restarts. The touchpad is connected to D2.
here’s the code
const int TOUCH_BUTTON_PIN = D2;
pinMode(TOUCH_BUTTON_PIN, INPUT_PULLUP);
attachInterrupt(TOUCH_BUTTON_PIN, doorButton, RISING);
What am I doing wrong panicking the photon?
Thank you,
Mustafa
You missed out the interesting bit - how does your ISR look?
I guess you’ve got a delay() in there and that will definetly kill your controller.
yeah I do have a delay … i’ll try to remove it and check again.
Thanks :slight_smile:
