Attach a USB Device?
I have a Symbol LS2208 handheld USB based barcode scanner.
I currently have it attached to my laptop, and my Photon setup to print out the UPC via Serial.println() when you scan a barcode.
Rather than plug into my laptop, I'm looking for a way to attach this scanner to the microcontroller so I don't have to have a laptop.
Should I be looking for a USB Host Shield? If so which one will work? Should I bail on this and look for a bluetooth one with the new Photon 2?
There is no USB Host or OTG mode implemented on the Photon.
I'm also not sure when (if at all) Host/OTG would be supported in the P2.
This scanner also has a RS232 interface, so you could use that with the RX/TX pins (with level shifters!).
Thanks for the quick reply @ScruffR
Could you recommend a level shifter? This is still very new to me so I’d appreciate all the help I can get
@ScruffR
Would I use something like this?
My Scanner is USB however. Would I have to get a USB to Serial converter and then use this RS232 shifter or does USB variant exist?
I had only a very cursory glance over the LS2208 info I found, so I cannot completely say what voltage levels this device uses.
You'd probably need to find the exact electrical specs in the full datasheets.
However, when there only is a USB connector on the device I'd suspect 5V which would probably be directly usable with the Photon, as its RX/TX pins are 5V tolerant and the 3.3V output on the TX will usually suffice to constitute a HIGH level even with 5V logic.
The P2 on the other hand has not 5V tolerant GPIOs and hence would need 5V/3.3V shifting.
Thanks again @ScruffR. I'm just looking for some sort of direction/idea to move forward with.
A sticker on the scanner states 5v .2A and the manual has a power supply section that states 5 vdcv minimum 650mah.
Are you stating I could use something like this, which I have, and just supply my own 5v VCC and somehow tie the D- D+ to the proton RX to read?
There should be some datasheet with that scanner that gives some indication how to put that device into RS232 mode, what the default baudrate and protocol (e.g. 8N1) would be.
Starting at Page 6 will help you in reference to placing the scanner in rs232 mode.
